SOURCE: HOW DO I TAKE APART THE DASHBOARD ON MY 2006 FORD
If its like my ford ranger the dash is held together with small medal clips . start at the corner of the dash on the driver side and carefully pull the dash piece towards you. i've taken mine apart 3 times now and i find that the medal clips needed to be reshaped the third around make sure your vehicle is nice and warm or you will crack the plastic
SOURCE: my fuse blows everytime i plug in my sirius radio
is that the only device that is blowing a fuse? if it is the only thing blowing your fuse you may need to replace the charger. check the fuse to make sure it is the correct size ( usually 10 amp). check the power adapter to make sure there are no loose connections or anything in the plug that doesn't belong there. unplug the radio from the adapter and plug the adapter in without the radio see if the fuse blows . if it blows replace the adapter. if it doesn't blow the fuse check the adapter to make sure it is the right one make sure the polarity is correct
