Im guessing it did get wet but only a tiny rain drop. I took the battery out already for a while, about a week and it still dosent work. Is it possible that i need to flash it? Or did a wire come out of place?
BTW, thanks you for help and response. :)Im guessing it did get wet but only a tiny rain drop. I took the battery out already for a while, about a week and it still dosent work. Is it possible that i need to flash it?
You can't post conmments that contain an email address.
it sounds like 1(or more) of the motorised valves arent working.find the valve and make sure you are getting power to it via a tester,if so then it probably needs the head on the motorised valve changed
On the assumption that your bathroom is 8 ft high, then the volume of air in the bathroom is 5x8x8 or 320 cu ft. Even if your fan is 80 cfm it would take 4 minutes to completely exchange the air. Leaving the door slightly ajar would assist. To overcome a similar problem, I installed a second fan with a push button 10 minute timer so the fan runs for a few minutes after I leave the bathroom.
well if you had the phone less than 30 days you can probally try to retern the phone.and explain all the problems
(THIS IS A SUGGESTION)
NOT CERTAIN IT WILL WORK
