SOURCE: lg viewty ku990 bluetooth bd address not set
your board is faulty and will need to be exchanged by lg for free
SOURCE: LG viewty ku990 - no battery life and phone gets really hot
Hi
I dont know if this will help you, but it helped me. I had the same problem, with phone not holding charge and getting really hot both during and after complete charge.
I needed my memorycard from my LG to my other phone, so I took it out, and off course the phone needed to be charged so I charged it, and... it did not get hot at all, and when it was finished, the charge lasted a day and a half!! Now the problem is I cant use the memorycard anymore in my Viewty :S Win/Loose situation i guess....
I think that the bluethoot of your pc or your LG KU990 (Viewty) Has no name. Your bluethoot address have a IP address but for the windows you need to put nthe name. Give your device a name that windows can find and vise versa. Most bluethoot softawe find the phone but sometimes you have to it in a otherway. Remove the item in the profile list of your bluethoot software that you made it for the phone. Now sometimes you have to turn off and on your phone cause there will be a program still running on the background of your phone. So when you want to find your LG KU990 (Viewty) you have to do it vise versa. Find your Pc or Laptop with your LG KU990 (Viewty) in this way the bluethoot will find the address and ask you for a security code. In this case you can make a password. EXAMPLE 1234 or NicKy what ever you want. Then the bluethoot software will setup the modem drivers of your phone so you make an connection with the bluethoot. Sometimes you have to reinstal the drivers to make the software work correctly. I hope this will help you out. Fallow the steps when the drivers will be ready to install. Best regards; Henk Muskita.
SOURCE: i got no cd with lg viewty ku990, how do i connect
Check this link to get the LG KU990 (Viewty) Software pakket.LG Pc Suite.LG KU990 Drivers.You can also check for a device spoftware update.http://www.fixya.com/support/t2199749-disc_came_phone_not_fit_in
SOURCE: setting up wifi on my LG Viewty
Unfortunately the LG Viewty does not have wifi.
I also have a viewty, and I find that with a cheap data plan and the 3g internet speeds, lack of wifi isn't really a downside.
