Blue lights come on but no picture appears.an then tv shuts itsself off
SOURCE: JVC 42 INCH PLASMA POWER LIGHT BLINKING ONLY NO PICTURE
no kidding? what is the problem so prevelant in this unit? obvious design flaw.
SOURCE: my tv won"t turn on.
1. Hold [menu] and [vol-] button on the side of the TV
2. while holding these, press the [power] button on the side of TV (NOT remote)
3. blue light comes ON and stays ON
4. wait 10 seconds then let go of [menu] and [vol-]
5. wait another 30 seconds and some type of picture should appear
I think this is right. I got it from the JVC call centers guys so sorry if I missed or messed up a step.
SOURCE: No picture or sound!!
Call the tv warrenty serviced repair,tv under a one old right?The tv power supply board is dead,need repairing by replacing power supply parts call like capacitors common parts dies by leaking gases in the power supply board.
SOURCE: On/Off blue light blinking, TV won't come on.
Ur power ic inverter board is dead.
U need new one.
Testimonial: "Thanks for the advice. Will try it."
SOURCE: I turn on the tv then it turns back off on its own
I had a similar problem with my Phillips 42 in. LCD HD TV.
Here's the problem. The Power Supply Board. I opened my TV
up(warranty was up of course) and found several bad capacitors.
Phillips and several other companies were sold capacitors that although
were highly rated failed within 5 years because of a lack of
preservatives. All sorts of electronic equipment is now being effected
due to these defective capacitors.
Solutions?
1. Take it in and have it fixed
2. Open it up, check the board for faulty capacitors(bulged or leaking) Buy a new Power supply board and install it.
3. Remove PSB, remove faulty capacitors and replace with compatible new ones.
Hope this helps
