KitchenAid Kitchen Aid Kitchenaid 5-speed Ultra Power Blender Blenders 5-Speed Blender Logo
Anonymous Posted on Jan 05, 2013
Removing range door on Kitchen Aid model KEBI206DBLIO
Need to remove door on Kitchen Aid range to clean glass between door.
Anonymous
Level 2:
Sergeant:
  • Expert 475 Answers
  • Posted on Mar 12, 2013
Anonymous
Expert
Level 2:
Sergeant:
Answers
475
Questions
0
Helped
112419
Points
908
Look on the internet they can help you get that done.
2 Related Answers
Anonymous
  • 145 Answers
  • Posted on Jul 07, 2009
SOURCE: I need a coupling for
The piece that you need is referred to as the coupler. The coupler is a breakway part that is designed to shear and/or wear down in the event that the blender is overloaded. This is to avoid damage to the motor.
The coupler may be purchased individually and is an easy repair that can be done at home. You may purchase the part and access step-by-step replacement instructions at the following link:
http://www.mendingshed.com/kacoupling.html
Appliance engineer
  • 225 Answers
  • Posted on Jan 26, 2010
SOURCE: The coupler on my kitchen aid has broken
Try http://www.kaparts.co.uk/ they are usually in stock and sent first class.
1helpful
How to fix a Kitchen Aid blender, Model KSB5WH1, that won't start
It can only be three things
Switch
Motor
Broken wire (unlikely)
How good are you with a screwdriver and a digital multimeter at testing components?
https://www.google.com/search?q=Kitchen+Aid+blender%2C+Model+KSB5WH1
Jul 07, 2023 • Blenders
1helpful
Broken magnet of a Kitchen Aid Blender. Where can I find another one? KSB5WH4
From Kitchen Aid they only come on a new motor. I am a Kitchen Aid service agent and I remove them from burnt out motors and keep them. Look for a service agent near you and see if they can help you out. I have no idea where you are, I'm in New Zealand.
Removing over the hood microwave
There is no microwave hood on a Kitchen Aid blender
1helpful
I have a kitchen aid blender with a polycarbonate jar. The jar leaks at the blade. I noticed it has a plastic nut on the bottom with left hand threads. However the nut will not fit over the drive gear...
Older KitchenAid blenders had a jar that was made so the blade assembly could be removed for cleaning. On the newer models the blender jar and the blade assembly are all one unit so you have to purchase a new jar to get the blade assembly. All of this is dependent on which model of blender you have.
We would be happy to help you. Please a give us a call at 1-800-339-9297 we would be happy to help! One of our repair technicians can talk you through the repair over the phone free of charge. On the bottom of your blender is the model and serial numbers; have these handy when you call so we can help you order the correct part.
We have several blender jars on our Web site http://www.mendingshed.com/kitaidblen.html for KitchenAid blenders. If we don't have the blender jar that fits your model in-stock we can order it and ship it to you. Please contact us with any further questions. You can also email your model number or questions to [email protected]
Sincerely,
Mendingshed.com Staff
When I turn my blender on, it runs for only a few seconds, then stops and all the lights on the panel flash on and off.
More often than not it will need the motor to be replaced, only Kitchen Aid parts will do, motors are usually unique to brands and models. Sometimes it can be the control/button panel but normally the motor.
Whilst blending some vegetables I accidentally knocked the glass jar which rocked it, and the small base part that is connected to the whizzer broke. Now of course it won't work at all. Can I replace the...
Hi, you have broken the coupler (sometimes called a coupling). It is relatively cheap and easy to replace. In the UK, K A Parts Limited sell them here and provide removal instructions here.
Glass goblet/bowl for liquidiser
Normally stocked here: http://kitchenaidblenders.co.uk/Home/tabid/36/c/KitchenAid-Blender-Spares/CategoryID/6/Default.aspx
out of sotokc at present, expecting more by 5th Feb
2helpful
I'm having a hard time disassembling my Kitchen Aid blender. Does the container come apart from the screw on the underside, detaching the plastic from the glass?
Have a look at the instructions here:
http://kitchenaidblenders.co.uk/KitchenAidBlenderGlassJugJarDisassembly/tabid/157/Default.aspx
This is for the glass jar which may be slightlt different.
Beaters
KitchenAid Turbo Beaters - Stainless Steel
Model: KHM2B
$14.99
Features:
Replacement or Extra Set of Self-Cleaning Stainless
Steel Beaters Mix Cookie Dough Easily.
Turbobeaters fit only Hand Mixers manufactured since
September 1997.
If you have a model produced before 1997 please call
the KitchenAid Customer Satisfaction Center at
1-800-541-6390 with the model and serial number from
your hand mixer for further assistance.
Top KitchenAid Blenders Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a KitchenAid Blender Expert? Answer questions, earn points and help others
