SOURCE: Sony KDS-60A2000 projection TV: power led blinks 4 times
the projector bulb has gone out you need to replace it.
hope this helped
please rate well
If you need further help, reach me via phone at https://www.6ya.com/expert/mark_445a24324be9eb03
SOURCE: my power light is flashing red three times on and
The 3 blink code indicates that the lamp door is not secure. If you havent removed the door then its probably the switch for lamp door sensor.
I would remove the lamp door and then reinstall it. Do this with the set unplugged then plug it back in and check operation.. Basically sometimes the lamp door switches become dirty and by removing and reinstalling the door it usually corrects the problem..
If this doesnt work then you will need to either have the set checked out by a tv technician or you can try replacing the switch yourself. But as I said normally just removing and reinstalling corrects the problem.. Good Luck!
SOURCE: I HAVE A SONY KDS-60A2000
3 times red light blinking indicates that Lamp Cover has not been fixed in its location properly after lamp replacement.
Please make sure lamp cover (its first thing that was removed to replace lamp) is installed securely.
Thanks.
SOURCE: I have no picture and light flashes 5 times
If you pull the right side out (as you look at the front), get you ear down to the fan exhaust area and turn the set on. If you do not hear the fan turn or feel air being blown out, then you have a defective fan. It is a common problem.
Hope this helps,
Skyassoc
SOURCE: My Green power LED is flashing continuously.. no
Ur power supply board is dead,need a new one.
