Machine is making a strange noise through washing cycle and then an error service code #245 message came on
SOURCE: Code 037
Would be good if you checked your pump. Refer to your manual. The pump could be clogged with lint or other waste and is stuck. I can be done yourself. Rate if helped pl.......................
SOURCE: Smart Drive 703-strange noise during wash cycle
hi there these washing machines don't have any pelts or pulley's. Washer will need new seals and bearings witch is a big job, you wont be able to do it your self as you need special tools to put the bearings back in :)
SOURCE: Washing machine stopped after wash
Hi just read your posting.Now Error Code 136 is called Motor Stall.This means the Motor Controller was unable to start the rotation of the motor.The possible causes of this fault are : Faulty wiring to the motor,faulty or jammed motor,seized bearings or seals,faulty control module,faulty rotor sensor.or wiring to the sensor.Now has your machine been noisy on spin?Could you please confirm the model number of your machine.Has your machine been leaking?Does the machine get a lot of work? Please reply with additional information on the questions and I am sure I can help you track the fault down.Looking forward to your reply.
SOURCE: Hi our F&P iw810 washing machine makes a loud
sounds like tub bearing or stator is cracked it also can be the clutch between the two tubs check for any hoses or wires touching the rotor its worth fixing as its a very goog model you have
Testimonial: "Thanks for your feed back. Will try the things you sugested when i get a chance. If it is the clutch how hard is it to replace and how expensive?"
