I just purchased a Thomson Lyra 6675 (2Gb). Loaded some mp3 files on it in sequence. Play sequence is set to normal. I don;t know what order it is playing the files back in. It is not file create date, load sequence or alphabetic sequence. For listening to books, not having the tracks in sequence is a problem! Can you advise how I can get it to play in order? Thanks
SOURCE: How do I add music files to my Thomson Lyra jukebox PDP2860
The best way would be to use the software that comes with the Lyra but if you dont have/use it then you simply drag and drop the files as you do with the films.
The difference being that you must manually 'Profile Contents' which is in the 'Audio' menu, if you use the drag and drop method whereas the software does this automatically.
Your files will magically appear when you have done this.
SOURCE: thomson lyra 6675 mp3,wenever i start it, its locked n shuts down
There is a slide switch on the top of it that locks the controls. If this is in the locked position then the devices shutsdown again!
Also, the 6675 does the same thing if the battery is flat .... appears to start and straight off again!
