I am finding it difficult to format the SD card by the Nokia phone as set out in the manual. I have been told that the SD card is too big (GB) for my phone, is this correct? If it is too big, where would be the best place to get a card that is compatible with the phone?
The phone only supports 2GB or smaller capacity microSD cards. Walmart and Amazon both list SanDisk 2 GB microSD cards as in stock online. See http://www.amazon.com/SanDisk-MicroSD-Adapters-SDSDQ-2048-package/dp/B000OT94PO for one of these.
I've also seen the low capacity memory cards at a local grocery store.
The specs for the Nokia 7390 are available here: http://www.gsmarena.com/nokia_7390-1691.php . The manual is available here: http://nds1.nokia.com/phones/files/guides/Nokia_7390_UG_en.pdf . The Nokia approved microSD card is legalese to avoid responsibility if a badly manufactured card (cheap/counterfeit) does damage or fails to store your data.Go with a brand like Kingston or SanDisk that have a reputation of manufacturing good memory products.
I hope this helps.
Thanks for the help Cindy. I really appreciate it. I don't know a hell of a lot about this sort of thing so your assistance is awesome.
You're welcome. Cindy Wells (who has been there with having a memory card or USB drive with too large a capacity for the gadget. Then I have to find the right one from the storage box.)
SOURCE: my nokia 6500 cant detect my micro sd memory 1gb.. plz help
hi, i got the same problem and got to solve it. Try this...
1. the battery cover must be put on otherwise, the hp won't detect the memory.
2. try to fix the cover or hook by bending it.
Good Luck.!
SOURCE: i want to use micro sd card using with adapter in nokia 6600
try to format the micro sd card from mobile it will take time but do it ..
SOURCE: how to format micro sd card in nokia E63 mobile
From the tools menu select memory card..then take options and select format memor card...or u can format it by connecting it to pc..
SOURCE: Dear sir, I have nokia 3110
Welcome to Fixya !! There is a simple way of flashing a memory card.Put the memory card in card reader and attach it with the PC.A icon will appear in My Computer with the memory card name(usually Memory Card).then follow the these simple steps :
And you are done.Enjoy.
If it was helpful then please rate or a token of appreciation will be esteemed.
SOURCE: forgot password for memory card
process 1- (Easy) - get a data cable and connect your mobile with a computer, transfer all your data from memory to PC (you can access your data only from originated cell phone), now format the memory through mobile phone and transfer back your data into memory.
process 2- (some complicated) - install Nokia PC suit into your computer and download "file explorer.jar" from www.getjar.com and install that into mobile phone, Run the software in originated cell phone and go to "c:" there you can see a file named as "memory.XXX" or "memoystick.xxx" copy that into your PC and open that in notepad (right click on file, open with, notepad/word pad) there you can see your memory password/ put the password and open the memory.
in whole above process originated cell phone is required (cellular phone in which you have put the password) if you dont have the same phone it means you can not open the memory without breaking the password and you must crack the password and need to format, but dont worry if you worried about the photos and other data (excludng songs) you can recover them by using professional recovery software which are available on net, just googled and download a crack version.
dont forget to vote me if found helpfull.
