Question about Canon FAX-L800 Plain Paper Laser
Cannot send or receive a fax
Canon Super G3 HC1-1614.
We cannot send or receive a fax. I had our phone company check the lines and they said they can dial out and dial in so they think something has been pressed on the machine. I do not have the manual on the machine. Do you have any idea what would keep the machine from sending and receiving a fax?
Thanks.
6ya staff
SOURCE:
Anonymous
  • 59 Answers
SOURCE: Fax not receiving
Sounds like you have done a through job troubleshooting and its reacting like it should. Try this first press data registration and press # press down arrow to clear and press set scroll down to ALL and set. This will wipe out all programming. Then try sending. If it still reacts the same. You may need to change the main board
Posted on Aug 10, 2007
Anonymous
  • 106 Answers
SOURCE: Canon Super G3
try to download at www.eserviceinfo.com
Posted on Feb 29, 2008
old marine
old marine
  • 2261 Answers
SOURCE: not receive
I'm not familiar with the B120, but if you have an L120 the manuals are available here. The Starter Guide will explain receive mode options and setup instructions. The Advanced Guide will provide troubleshooting guidance.
Posted on Apr 17, 2008
didi2005
  • 727 Answers
SOURCE: Toshiba Super G3, e-Studio 170F
Fax display screen always reads, "Auto receive". When attempting to fax, the busy light flashes. Busy light stops flashing for 30 seconds, then starts flashing again.
Above is the default settings for the fax.
NGB0 indicates signal error or line condition error.
U need to check the phone line. U can hook any single line phone to the phone line, check for tones without background noise.
Posted on Feb 26, 2009
Tim Swiercinsky
  • 1126 Answers
SOURCE: Cannot receive faxes
Make sure that the telephone line from the wall is plugged into "LINE" and not "PHONE" on the fax machine. You might also call the fax number from a different phone to see if you can hear the fax tones.
Posted on Aug 20, 2009
HOW CAN I SEND A FAX WITH CANON SUPER G3
Insert the fax. Prepare the documents you need to fax. Place the original paperwork face down with the top edge first in the Automatic Document Feeder.Set up the cover page. Press the "Menu" button, and then press "2," "2," and "8." When "Next Fax Only" appears press the "Set" button. Use the arrows to select "ON" and then press "Set."Select a cover page comment. The comments available for the fax receiver to view include, "Please call," "Confidential," and "Urgent." Use the arrows to select a comment and then press the "Set" button. Input the number of pages you are sending and then press "Set" again.Enter the phone number. You can store phone numbers in your system under the one touch dial or speed dial options. Use One Touch, the key pad, speed dial, or search to enter the phone number you would like to send your fax to.Send the fax. Once the document is inserted, the cover page is set, and the phone number is entered press the "Fax Start" button located in the bottom right corner of the control panel. Your fax machine will then dial the number and proceed with sending your documents
Apr 16, 2011 | Computers & Internet
Canon fax-l1000 super g3 - is it possible to operate this as a printer ? if so, is it possible to get a wireless adapter?
"canon fax-l1000 super g3 - is it possible to operate this as a printer ?" (sic) I have researched and NO you cannot do that.
The best you could do would be to Fax images.documents from your PC to this machine, that would effectively work, you would need a modem in the PC though, otherwise it will work fine... BUT not as a printer, as such. But you would still have the ability to store and manipulate the documents IN the Fax when received, and may just work, well, but with limitations?
You would simply have to dial the fax from the PC and send it to it, then it would receive,,store and print out as you wished... should/could work just as well as a wifi printer?
Aug 09, 2010 | Canon FAX-L1000 Plain Paper Laser
Canon Super G3 Laser Classs310 all in one. Has lines in copies and when receiving faxes and sending faxes. How do I resolve this problem?
Check toner crg. if there are streakes on drum change toner crg.
If not there is problem with fixing system.
Jun 07, 2010 | Canon Office Equipment & Supplies
None of our faxes are going out and we receive error number 87
set the fax so you can hear dial tone... if no dial tone then check the fax line.... if fax line plugged in... plug it out of the fax and plug into a phone... if still no dial tone then change fax cable... if dial tone... then call your cell... if static... fax wont work call phone company... if you get a funny signal call phone company...
I’m happy to assist further over the phone at https://www.6ya.com/expert/norman_d2fa496dce30c65d
Dec 10, 2009 | Office Equipment & Supplies
CANON SUPER G3 FAX-L220
0)use this link http://www.canon-europe.com/Support/Consumer_Products/services_locator/index.aspx
1)try to fax to your mobile phone wether u can tranmit or make a call to your fax number see there any respond.
2)check with your service provider on your line issue.
3)pls give me feed back after solving fault.thanks
Aug 26, 2009 | Canon Office Equipment & Supplies
Aug 20, 2009 | Canon FAXPHONE L80 Laser
Super G3 brother IntelliFax 3800
Sounds as if the tel line is not connected. 1st check with a telephone, see if you get a dial tone. If not then call the tel company
Mar 07, 2008 | Brother IntelliFAX 3800 Plain Paper Laser...
HELP
We also have losted our manual and need to reset everything but can't rember how to do it.. Can someone please help me out on this problem. Very much appreciated!!
Jan 22, 2008 | Canon - SUPER G3 FAX BOARD-T1 (0450B002AA)
Super G3 Fax Machine by Canon
Can you get a dial tone?... check that you have pluged phone line in to correct socket and that phone/fax line works with standard phone.
Oct 16, 2007 | Office Equipment & Supplies
Canon FAX-L800 Plain Paper Laser Logo
Clive
Clive
old marine
old marine
Ekse
