Just replaced both ink cartridges (78 & 15), and now all that prints is the black and magenta ink. have tried cleaning cartridge heads, taking out and replacing cartridges, etc.
Can't seem to find the printer svcs option folks are mentioning...
Any ideas? Thanks!
SOURCE: Brother DCP-130C refuses to print the magenta ink
If you don't print at least once a month, you will clog the machine. You unfortunately have to get it fixed by a professional or get a new printer. Sorry!
SOURCE: Problem printing with HP Business inkjet 1200 1-800-532-4187 IS SPAM
I have a HP Business Inkjet 1220 Printer, and the block ink cartridge light is flashing. I replaced the cartridge with a brand new one, closed the door, and black ink light is still flashing. I put in another neew black ink cartridge, closed the door, and same issue- black cartidge ink light flashing. I cannot print- what to do?
SOURCE: officejet d135 - "Supply Expired" error message
HP, in order to sell more ink, monitors the expiration date of the cartridges installed. Solution is either to buy a new unexpired cartridge from HP or to disable the date monitoring built in to the printer. This latter is done by removing the button cell located inside the D135 printer on the left hand side or by simply slipping a thin piece of plastic between button cell and metal contact. You will no longer have date function on printer, but it won't object to expired cartridges either.
SOURCE: printer replaced with black cartridge, and doesnt print
Either the print head for black is faulty, or the wiring to the black print head on carriage are broken. Try also cleaning the metal sensor to the black cartridge inside the ink carriage.
SOURCE: epson 9600 magenta won't print - have new cap assembly installed
The ink should come out of the cart. if not the cart is the problem at this point try anothere magenta if that does not shore it up then you need to then start looking at the print head where it goes it itself now the store you bought the ink from will give you a replacement no questions asked sometimes even if you dont got the reciept. Try those steps you be glad you did.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
these are fresh 15 and 78 cartridges, but blue will not print. Even when I tap the color cartridge on paper, only magenta and yellow leave an ink spot.
