The cell phone adapter piece that plugs into the wall has a tmobile car charger that fits into this adapter (for home charging use). The tmobile car charger still works; but when I put the charger into the adapter and plug it into the wall, it no longer works. If the adapter got wet somehow, can it be repaired.
SOURCE: Hello, my godmom just purchased a Brand new
Its very hard to pinpoint the problem from your few descriptions. However since the light came on it mostly means the charger should be okay. As for the phone, if the battery is really dead, it sometime takes up to 30 minutes before it shows that it is charging. SO leave it plugged in for some time to see what happenes. If it did not come on after that then the phone is bad. Just to make eveything sure, you can also try any other MINI USB charger or a simple MINI USB cord to the computer to charge the phone with as well. They all work on the Blackberry
SOURCE: phone wont stay on unless connected to power
i think your battery is to old, try buying a new battery
SOURCE: My battery charger that plugs into the wall does
prob need a new wall charger this is a common problem
SOURCE: Blackberry cell phone got wet; won't work
I cannot remember where i found this but if you look around the internet you may be able to soak it in distilled water and dry it out completely. Apparently the reason for short circuiting the device is due to the mineral itself not the water. I would suggest looking in to that. Hope this helps
SOURCE: My phone was working at
Dear Anthony,
It seems that over charging has damaged your gadget's motherboard or battery mechanism. You have to get it serviced. But still you can try by Removing your battery for 1 hr and then after re insert.
