I have toshiba Qosmio X775-3D78, few month back I change mother board when it was in warrenty and after that when service center installed ram same it was not starting, after they figure out one of the ram is not good after I bought new 4gb ram with specification with other ram, when i installed problem was still there its was not starting, only one slot was working, now is there is any solution for this or have to change mother board again???? Rams are good tested on same slot.. secondary slot is not good.
SOURCE: New hard drive for my Toshiba Qosmio G15 R laptop
I believe with Toshiba they normally would give you a recovery disk and then a drivers and utilities disk as well. If you don't have both then I would suggest installing windows xp and then go to this page:http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=SB&os=&category=&moid=835452&rpn=PQG10U&modelFilter=G15-AV501&selCategory=3&selFamily=804517Click on the downloads button and from there choose your operating system and you can download the drivers from that page.You'll know which drivers you'll need by going into the device manager and seeing what has a yellow question mark next to it.If you need more help with this let me know and I'll help you more.
SOURCE: how do i install 3D for Toshiba Qosmio X775
The 3D capability should be ready to go if you bought it new. Put on the special 3D glasses that came with it, and press the soft-touch button labeled "3D" near the LCD screen between the speakers... Don't forget to but the batteries in the glasses (or charge them if permanent), and turn them on...
