Bought a Lenovo G585 and just wondering when it is booted up why there is not a normal desk top look with icons, etc. Seems tough to navigate around, get to internet, etc. Just want it to go to the desktop when booted up. Shutting it down is also tricky to find, I usually have to do ctrl alt del then I see a shut down button.
SOURCE: Error Message Upon booting up
go to bios and load defaults. if still same thing happens after reboot. Boot from OS cd, on windows etup page, choose "R" to run recovery console. Choose OS. Run CHKDSK /R.
SOURCE: Compaq notebook won't boot up
Hi
When you boot the computer back up go into Safe Mode and check to see if you can roll the computer back to the point before you installed the software.
If so this should work. If it works then run a virus scan, a defrag of the hard drive and cleans the temp files.
OR
You can do a diagnostic startup and uninstall Onecare. So once that it is uninstall ed it should be smooth sailing.
Here is a link for some startup / diagnostic software you could try after booting.
I hope this helps
/Shawn
SOURCE: cant see desktop screen
Try this if your problem sounds the same or similar:
I purchased the HP-Compaq C765TU Presario, serial # CND81233B5, from Octagon Computers. My notebook came with only "Freedos" because I was going to Dual-boot Windows XP Professional & Linux, but I found out that my notebook is only “Vista Compatible,” because I could not find the drivers for the sound card & Atheros wireless adapter & the Linux I used, Ubuntu does not have all the drivers needed, so I uninstalled, & I added the only Windows Vista OS that I could get here at Octagon Computers in Tacloban City, Leyte, Philippines, “Windows Vista Starter!” (I’m an American married to a beautiful Filipino woman 1 year younger than me, & we are living in the Philippines. I’m, also, Retired USAF.) I went to the HP-Compaq site & downloaded all the new drivers and essential update for my notebook to make sure my notebook was as it should be by HP-Compaq standards. All is well, but only for a little while!
The first problem that I encountered was that after I would Logon, the Welcome screen would do its processing then go to a blank desktop with the cursor - no icons, no taskbar, nothing, so I used “control, alt, delete” to bring up the tasks page & started Task Manager. I found that the “Explorer.exe” was not listed, so I ran a “New Task” from the file menu, & my whole desktop came up. The notebook runs fine after this is done, but I had to do it all the time.
So, I found & bought a copy of Windows Vista Ultimate on the Internet & was forced to do a clean install because it was a full version (not an upgrade), which formatted my Hard-drive, but I had backed up all my files ahead of time, so as to not lose all my important data. I went back to HP-Compaq site & downloaded all the new drivers and essential update to make sure my notebook was as it should be by HP-Compaq standards. After doing this New Install, my notebook worked perfectly! However, the same problem has come back as I had with Windows Vista starter.
I have always used Anti-virus, and I run “System Mechanic Professional 8” because it has all the tools needed to seek & destroy viruses, spybots, etc…, & recover/repair data.
I have never had this problem with Windows XP Professional, but this laptop is designed for Vista, and I didn't know that before I bought it. I'm still looking for a permanent FIX. There must be a way to fix this problem permanently!
SOURCE: pavilion dv6700 locks up; mouse & keyboard frozen;
If you take the battery out and unplug the AC power the laptop will shut off.
SOURCE: when my thinkpad boots up I get the following
Sounds like a problem with your hard drive, you could follow this guide to make a bootable diagnostics CD to try to determine the exact problem.
http://forum.notebookreview.com/lenovo-ibm/224671-having-issues-w-your-thinkpad-diagnostic-guide.html
