Question about Splendide 2000S Front Load Washer / Dryer
Splendide 2000S Washer/dryer won't wash/dry. Noise then stops, then dial clicks around endlessly.
Hi we got this used from someone a few months ago. It had a broken handle when we got it and was excruciatingly loud on the spin cycles but other than that worked great. but suddenly 2 days ago it stopped working. The machine itself turns on fine but when we set it to any cycle it makes the typical start up humming noise (as if starting) but then stops. It does this a few times and then the dial marker just starts clicking around the dial endlessly until we turn the machine off. We're going to call the company today and see what they can tell us but any suggestions would be appreciated :).
    New Friend:
  • 124 Answers
Sounds very much like the bearing has seized on the drum.
can you turn it by hand?
I'm betting it's either stuck or REALLY stiff
Posted on Apr 17, 2017
4 Suggested Answers
6ya staff
SOURCE:
Anonymous
  • 21 Answers
SOURCE: unit runs good through wash cycle then while in
Sounds as if the drain pump is not ejecting the water fast enough. Did you notice of the washer is draining more slowly than usual or at all?
Posted on Feb 14, 2010
GodBlessU
Aparajita Batabyal
  • 3513 Answers
SOURCE: I have a 2100 Splendide vented washer dryer in my
Please check this link bellow to have an indepth knowledge to your problem....
http://www.repairclinic.com/Washing-Machine-Troubleshooting
Let us know if you have something more to know else accept the suggestion.
Thank You for contacting Fixya.com
Posted on Aug 16, 2010
SOURCE: the spin cycle will not spin. I hear a slight
I believe the motor coupler needs replacing -- it's the part connecting the motor shaft to the transmission / drive. Fairly easy for an accomplished handyperson to repair. The part costs around $20.
More info, let me know.
Charlie
Posted on Mar 30, 2011
Testimonial: "thanks I will look into that"
Can i use a cheaper alternate control board for my Splendide 2000S Washer Dryer Combo?
to do what you are saying is to remove controler and by pass every thing with individual switches would work in a fashion but is not feasable best dump it now or repair propely for safety reasons remember a life is worth more than any money when playing with electric and water repair or get new dont take chances a family menber is is loved and would be missed
Aug 14, 2012 | Splendide 2000S Vented Washer/Dryer
Splendide 2000S Vented Washer/Dryer makes a bad noise once in the rinse cycle and water will not drain
Check the drain pump. There may be a coin, hairclip , button etc stuck in the blades of the pump. If the machine cant pump out, it wont go through the cycle.
Sep 17, 2017 | Splendide 2000S Vented Washer/Dryer
2000s washer dryer combo is not drying with ht air only cold why?
The heater element is likely failed.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jul 10, 2009 | Splendide 2000S Vented Washer/Dryer
I'm buying a used splendide 2000 do the water line have to be hooked up to run the washer or dryer
if they do then the machine will bring up an error code if not then it will run fine on a dry run
Jun 11, 2009 | Splendide 2000S Vented Washer/Dryer
Splendide 2000S
www.splendide.com
1-800-356-0766 #5 (503-656-2280)
503-722-9202
service@westlandsales.com
Monday-Friday, 7:00am - 4:30pm (PST)
You may also want to try a RV retailer in your area, they may direct you to a used part.
Jun 10, 2008 | Splendide 2000S Vented Washer/Dryer
Splendide 2000S Front Load Washer / Dryer Logo
184 people viewed this question
Top Splendide Washing Machines Experts
Marvin
Marvin
Ekse
peter gittos
peter gittos
Are you a Splendide Washing Machine Expert? Answer questions, earn points and help others
