I have problem and i did install new windows from recovery disc, every thing is ok but its not showing model of my qosmio X775-3D78 in dialog box when you take property of my computer it shows Model 00000000000000000000 and same serial and part number... Any solution will be highly appriciated.
Ok, feb1, old post
installed what OS>? version.
dialog box
what box.? are you in BIOS or windows, if windows where are you? in CP+system?
my guess is you did not load all the software drivers from
the Toshiba web site.
no say what where you got that disk?
who made this disk or bought from.?????
we cant read the top of your disk, and there are endless sources of disks now, mostly bad.(infected too)
dialog box
what box is that, what are you running to get to this box, we have no cue from you.
1000s exist. (boxes to type) in 10,000,000 of applications.
SOURCE: Qosmio g15 recovery disk error
If the discs are clean and pretty much scratch free, then this is most likely a bad hard drive. If you have another PC or laptop, try burning copies of the recovery cds and then use those. If the problem remains, you will need a new hard drive.
SOURCE: I am in need to install recovery console
Here's How:
Boot From the Windows XP CD
To enter Recovery Console in Windows XP, you will need to boot from the Windows XP CD.
Press R to Enter Recovery Console
When the Windows XP Professional/Home Setup screen appears, press R to enter Recovery Console.
Choose the Windows Installation
The Recovery Console
is now loading but needs to know which Windows installation to access.
Most users only have a single Windows XP installation so the choice is
usually clear.
To the Which Windows installation would you like to log onto question, press 1 and then Enter.
Enter the Administrator Password
now needs to know the administrator password for this Windows XP
installation. Unless you are using a PC in a sizable business network,
the administrator password is most likely the same password you use to
access Windows XP on a daily basis.
To the Type the Administrator password request, enter the password and press Enter.
Note: If you do not have a password or Windows XP normally starts without asking for one, simply press Enter.
Make Necessary Changes in Windows XP Recovery Console
The Recovery Console is now fully loaded and the cursor should be sitting at the command prompt, ready for input, as shown in the screen shot above.
Make any changes necessary in the Windows XP Recovery Console. When complete, take out the Windows XP CD and type exit to restart the computer.
bootcfg /rebuild
Type Y in response to this question and press Enter.
This is the name of the operating system. For example, type Windows XP Professional or Windows XP Home Edition and press Enter.
Type /Fastdetect here and press Enter.
Assuming that a missing or corrupt boot.ini file was your only issue, Windows XP should now start normally.
Show your appreciation by rating it.
SOURCE: Installing windows XP - Error encountered
Can you reboot and get into windows or is now corrupt?
What do you mean by 'uninstalled XP'??
You cant uninstall it unless you format the drive, in which case the recovery discs are now probably useless as they rely on a folder on the HDD called i386.
Recovery discs normally dont have the OS on them, they rely on the I386 folder to gather info about the computer and then restores it to the state when it was new.
If you can acess the system, reboot and go into the bios and change the boot sequence to CD, then insert the first recovery disc. then save the settings and the computer will reboot and start the recovery process again, this should clear up the error.
If it does not it will be because the i386 folder is missing in which case you can either explore the recovery discs for it or you will have to buy a copy of Windows XP.
SOURCE: Toshiba Satelite a135 s2386 USB problems...
How to use USB hub if my all 4 usb ports are dead?
