TURNS ON BUT CANT HEAR ANY ONE OR TRANSMIT
Can you see the s-mete if it has one moving up and down on any channel? Do you hear any audio at all? could be a couple of things. Bad mic switch or mic cable, bad antenna or coax, bad audio amp. To check the audio amp plug in a speaker to the PA jack, put the PA switch on PA then press the mic to talk. If it works the audio is fine the mic is good and the mic cable is good. Noiw plug the speaker into the speaker jack, do you hear anything? If not then your antenna or coax has a problem, fix or replace antenna or coax.
