When i hold power key, it just vibrate and not turn on ! what can i do ? and when i connect the charger, just the red light appear and blinding...
Good morning:
First Option:
mostly nokia chargers doesn't make problems...
just try the following..
connect ur mobile with a system (usb cable)...
found out whether it is charging or not...
if the same prblm appears then there is a prblm in ur cell phone or power jack(socket)...
if it charged with usb cable buy a new charger
Please change Phone Bettery and check the charging
IF Charging Problem not Solved So
Second Option:
Your Phone charging IC Fault So Please change charging IC
And charging Problem will Solved Quickly
SOURCE: My phone is not charging
it may cause by the charger,do little shake on the plug that connect to the phone..red light appear cause by no battery at all..
