its difficult to explain the dc are going to the thermostat and from the thermostat to a element that warms the outside to make cold in the inside does it have a pc board or not be free to ask questions
camper ? grey water is used water tank from sinks and showers the gauge I guess is an indicator to show how full tank is (I never had a gauge to tell me), if camper is large then yes it could have two tanks , I will say if there under floor , and you move camper a lot then its best to maintain a even level in both tanks, no sense to make one side heavier than other , remember water is 8.33 pounds per gallon so it wont take too much difference to unset the balance of camper on the road
? 1:47
https://www.youtube.com/watch?v=7iRxF4DfNRE
Feb 28, 2013 - Uploaded by Matt Sain
Removing a front cap on a fifth-wheel camper ... front cap on afifth wheel camper so we can repair the sub frame & pin box that was cracked.
Apr 16, 2009 - 23 posts - 3 authors
Driving down Rt. 95 I passed a Fifth with his whole nose cap ... why other areas haven'tcracked, unless they're made from different materials.
Jul 15, 2007 - 27 posts - 19 authors
Metal tore on the fifth wheel hitch itself, or from the truck bed attach brackets. ... here's a few pics notice kingpin pushing up on trailer nose cone ...
Norcold fridges are now part ofThetford one of the largest suppliers of mobile and marine products. You do not quote the model so not sure if a 3 way (gas/mains/12v) or AC/DC. The most common problem with all mobile fridges is the heater unit is faulty. Thetford have discontinued spares for a large range of norcold models. Information can be obtained on the Thetfold.com website.
Good Luck
Even if your plugged in, you'll have to confirm you have 12Volts DC going to back of fridge at connections, behind vent cover. Is the upper board on front of fridge lighting up when you turn it on? Could you also give me model number off fridge to help guide you better ? Model # should be on inside of fridge.
One of two problems. The auto switch is bad or the lower circuit board is not doing its job. You can call norcold technical or take the board to a service center and have it checked with the tester they should have. The lower board retails for 176.00. I looked at my tech file and it is a little vague on your particular situation. If I were repairing your fridge I would take the smart route and call technical. Hope you get your problem solved. If you need more help please feel free. Regards
in your refridgerator there is an internal thermostat on the cooling fan u can move up or down it should be placed on the last finn to the right looking at the fridge
thanks
cruz
cruz's mobile rv repair
