The mute button seems to be working fine, but regardless of how it's set, Skype or my computer isn't able to pick up any sound from the mic. It was working perfectly until now, but overnight it just stopped working completely. I've messed with the sound settings. It is ON and should be able to work, but it just doesn't. I've reinstalled the drivers and nothing seems to be working, please help
SOURCE: Lifechat LX-3000 refuses to let me speak
I had the same problem which I traced to a manufacturing fault. I had to break into the control box halfway along the cable (you will defintiely void warranty doing this!) The cable connection from the headphone to the control circuit was not properley terminated (some cable insulation was melted through to bare wires). You have to re-terminate this cable so you need skills cutting/stripping wires and resoldering, and if you attempt any of this don't expect to be able to complain or ask for a replacement under warranty.
SOURCE: Microsoft LifeChat LX 3000 volume buttons on remote does not work
Follow these steps:
1. Go to Start > Run and type "services.msc" without the "" and hit Enter
2. Scroll to "HID Input Service" and start the service.
If you get error code #2 follow these:
1. Go to Start > Run and type "regedit" without the "" and hit Enter
2. Got to the following key "HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\HidServ\Parameters" and create the following key...
2a. Right click and select "New" > Expandeble String Value:
2b. Name: ServiceDll
2c. Type: REG_EXPAND_SZ
2d. Data: %SystemRoot%\System32\hidserv.dll
3. Save and close de Registry and do the first step (Start the service).
That should take care of it. Hope it helps.
SOURCE: I have a Microsoft LifeChat
Problem with the Microsoft LifeChat? LX-3000 Headset hi i just bought microsoft live chat lx3000 it works ok with skype or msn but how do i use it to listen to my music or how to instal driver
