Fisher Paykel EcoSmart GWL15 Logo
Posted on Jan 19, 2009
Hae we have a fisher and paykal washing machine but it wll not start spinning can u help
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Jan 20, 2009
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
393
Points
Run a diagnostic test for the spin cycle. The paper to show you how to run these test is located under the control panel normally two screws on the back of the control panel. By running the diagnostics, it will code if there is a problem and you will know what to check. You can also drain your machine with these diagnostics.
Does your machine beep (because there is a problem) during the drain process but doesn't get to the spin cycle? More than likely your drain hose is clogged. It is very easy to check this. I had the same problem because my machine could not drain properly and would not get to the spin cycle. There was a penny in my drain hose. There is a video on youtube that shows you how to do this (very informative).
F & P MW511 Washing Machine ... Driving me Mad ... Please Help!
Size setting
Action - Reselect the size of Smartdrive by using the SIZE SETTING MODE. Push and hold
the water temp up button, then press the power button to enter SIZE SETTING MODE. Three
LEDs are used to identify size.
The cold water temperature LED identifies 5kg.
The low water level LED identifies 6kg.
The hold spin speed LED identifies 7kg.
If the product has not been setup before all 3 LEDs will be on.
To set the size for 5kg push the wash temp up button then
the power button.
To set the size for 6kg push the water level up button then the power button.
To set the size for 7kg push the spin speed up button then the power button.
This locks the size
into memory. To check the size is set, start a cycle.
I have a Fisher and Paykal Smart Drive 053 washine machine. It has just started doing the following: Start load - Cold, warm or Hot and any size Fills intermittent. will fill for a couple of seconds...
Hi just read your posting.When the machine stops and starts does it beep and show an error code.This error code will be a series of lights that light up and the machine will beep.On the wash progress line of lights which lights are lit when the machine beeps,Is it the 1st and 6th or the 4th and 8th etc.Please reply with additional information and I am sure I can help you rectify this fault.Looking forward to your reply.
Hi i have a fisher & Paykal IW812 Intuitive Eco washing machine it gets to the rinse drains a little water then nothing happens time still counts down but nothing happening gets to the spin cycle then...
Hi just read your posting.Unless the machine shows an error code the diagnostic mode will not help.Does the machine agitate in the wash cycle?Does the machine drain the water completely?Does the machine spin the clothes dry.Please reply with additional information on the questions I have posted and I am sure I can help you rectify this fault.Looking forward to your reply.
2helpful
Fisher and paykal IWL16 washing machine showing fault 37 tub not emptying or spinning when put on spin cycyle
Hi just read your posting.Error code 37 means PUMP BLOCK ERROR.Drain some of the water by hand enough to look under the machine to the front right.Do you see a fan.If you do this is your pump.If you do not see a fan then you have the new style of pump.Please reply on which style of pump you have and I will guide you in rectifying this fault.Looking forward to your reply.
3helpful
2answers
Fisher Paykal GWL-11 won't advance through cycles. Could this be
maybe blocked drain pump can u hear a buzzing when it tries to drain water
2answers
Fisher & Paykal washing machine, Mod:GHL10US
if you want to find out for sure post your email here and i will send you the service manual
2answers
Fisher paykal top load washing machine
I had the same problem. I unplugged the machine for a while (overnight) and it then worked properly when I plugged it back in. Probably just a circuit board issue that was cleared with the power removed.
Top Fisher Washing Machines Experts
Paul Bade
NOEL
NOEL
Are you a Fisher Washing Machine Expert? Answer questions, earn points and help others
