Model # T3112 S/no XRZ59 500 01633
SOURCE: i bought a used computer
this tool will reset the Windows Admin/User password & BIOS/CMOS password
This is the right tool for you!
Works on USB drives too so no need to burn onto a CD but i would recommend cd as it less hassle.
http://rapidshare.com/files/135356745/Reset_Any_Windows_Password__including_Vista.by_AlbWteaM_.rar
password to extract is www.albwzone.com
SOURCE: Password promblems
If your OS is vista, follow the steps in the following link
http://www.vistax64.com/tutorials/102005-reset-user-account-password.html
If your OS is MAC, then follow these instructions,
Although there’s no real way to recover a lost root password, youcan change the root password even if you do not know the current one.You must have physical access to the machine in order to accomplishthis task.
1. Click Restart at the login window
2. While the computer is restarting, hold down “Command-S” until yousee text scrolling through the window. This boots the computer intosingle user mode.
3. At the Localhost% prompt type:
/sbin/fsck -y
/sbin/mount -uw /
/sbin/SystemStarter
You will then see various services starting up.
4. When the Localhost% prompt reappears, type:
passwd [username]
It will then ask you to type the new root password twice, so do so.
(Though I’ve not tried it, it appears you can type niutil -list ./users to get a list if users if you do not know the username….ifsomeone wants to verify this, I would be most appreciative).
5. After entering the new password, type:
reboot
6. At the login window, enter the username with the new password.Once you are logged in, you can use the Multiple Users application(/Applications/Utilities) to change your user’s password, or create anew user account.
Note: this may not work for newer versions of OS X; I think they didsomething about it in a security update. I hope this helps you with Macintosh password recovery.
Hope this helps,
~regards,
Jegan
SOURCE: dont know how to use restore cd for emachine w3609
The restore CD provides complete backup of the software that was preinstalled on the PC at the factory.It wont provide you the access or bypass the admin password.
You will have to reinstall the OS using the restore CD,You can do this by booting from the restore 1 CD, change Bios settings to boot from CD/DVD.
Note -- You will lose all your data in the primary partition.
SOURCE: forgot password for my emachine computer
Boot your pc into safe mode, usually F10 as the pc power on, Go into the Control Panel, then users and you should be able to delete your account's password from the user's manauel.
Good Luck
C2Solutions
