This computer mutes on it's own randomly and continuously over the course of the last few months. Researched to find what it to be called a "launchboard failure." I don't know how to fix this.
Launchboard is the panel with buttons situated over your keyboard. If some kind of conductive dirt, fluid or water came inthere, it will short out the keys and "press" them giving you that problem. Try to clean the board with alcohol.
Wiping the surface with alcohol or should I remove the whole cover and then wipe it?
Try just wiping the visible parts of the panel and see what happens. If this does not help, you need to remove the panel, referring to the manual from Lenovo, how to take it aparthttp://goo.gl/mbJdQ
SOURCE: I have a lenovo ideapad
Welcome to FixYa!
This may cause by an electrical charge in the motherboard itself,Im not really sure how it affects the display of the computer.There's also a possibility that the problem is with the LCD cable or the LCD itself. Please follow this method since it usually fix such problem like that,
1.Removed the battery then unplugged the AC adapter
2.Press and hold the power button or the ON/OFF button for at least 30 seconds
3.Connect the power supply back to your computer then turn it back on.
4. Check if you will see any difference.
5. If nothing happens, try to press and hold Fn and F2 on the keyboard.
If nothing happens, there is a possibility that the problem is with the LCD or monitor itself, maybe it will need a replacement...
I hope this information will be helpful. Thank you for using FixYa...
SOURCE: Hi, My Lenovo Z560 laptop has
Welcome to FixYa
The softkey buttons on your system is controlled by the lenovo energy management driver software. Try reinstalling this. You can download it here
www.consumersupport.lenovo.com
Enter the serial number of your computer which is located on the bottom of the system. Look for the S/N number on a white sticker. Dowload and install lenovo energy management. Restart the system and check if that fixes the issue
Hope this helps
SOURCE: i purchased a lenovo z560 laptop last month, but
If you are interested you can use external mini usb keyboard.
If possible call to lenovo call center and ask for replacement of key board.
SOURCE: how do i enter supervisor password on my lenovo
Step 1: Enter Safe Mode
a)Start or re-start your computer.
b)Before the Windows 7 loading screen appears, Press 'F8? to enter Advanced Boot Options.
c)Use arrows to choose 'Safe Mode' when you can see the Advanced Boot Options screen.
d)Press 'Enter' and wait for Windows 7 files to load.
e)Log on with an administrator account when you can see the log on screen
Note: Well, when you are presented with the Advanced Boot Options screen, there are 3 types of Safe Mode. They are the Safe Mode, Safe Mode with Networking and Safe Mode with Command Prompt, and the 3 options are all available for you. Here above we take Safe Mode as an example, but if you choose Safe Mode with Command Prompt, you'll need to input related to command prompt to reset the password.
Step 2: Reset the forgotten Windows login password in Windows 7
Now you could diagnose and solve some serious computer problems in the safe mode and reset the forgotten Windows login password in Windows 7 as follows:
1.Click 'Start' button, input 'lusrmgr.msc' into the Search box and press 'Enter'.
2.In the 'Local Users and Groups screen', click 'Users'.
3.Right-click the account that you need to reset the password for, and then click 'Set Password'.
4.Type and confirm the new password, click 'OK'. (You can go to 'Local Users and Groups' screen by right-clicking 'Computer' to select 'Manage' on desktop.)
Step 3: Log on your password protected PC again with the new password since you have successfully performed Windows password reset for Windows 7.
SOURCE: Computer hangs up due to power failure:
1) Replace your laptop's battery.
2) Run Reginout Scan.
thank you....
I've reformatted the computer, reinstalled all drivers. The last thing I haven't done is updating bios which the computer does not allow me to do.
