SOURCE: erro de objetivo apagar automaticamente reiniciar
Hi there please follow the steps and let me know the result.
1. Ensure batteries are fully charged & clean the battery connector point in side the battery compartment.
2. Look carefully between the lens and the camera body for any sand, dirt or any damaged etc.
3. Try turning the camera with the lens facing down and shake to dislodge anything stuck
4. Try removing batteries and memory card, wait 5 minutes and refit the battery only.
5. Now turn on camera( with out card ) and see ,if working then fix the memory card & again turn on the camera. If working then fine .
Otherwise format the memory card and fix back in camera again & try. Make sure before format the memory card take a
back up all photos in your computer then format. If no luck then reset or restore the camera setting by pressing Menu key for 2 sec ..
in not done the press both Menu & self time key for 2 - 4 sec.
i hope it will gives you success. Thanks & Before you leave, if you have found my information helpful and if you haven't
already done so then please press the ACCEPT button, this is how I am paid for helping you today. POSITIVE feedback & bonus is appreciated
SOURCE: error de objetivo reiniciar camara
El origen de este error se encuentra en el mecanismo del zoom.
Existe una corona de reduccion o engranje de doble corona que hace la
rotacion del mecanismo del zoom, que al forzarce se le desprenden unos
dientes (plasticos) y comienza a patinar en el lugar Esto pasa también
cuando se cruza el lente de zoom,cuando se rompe una o mas guias ,lo
cual ocasiona que los sensores de foco y demas no logren su propia
calibración y es ahí cuando la maquina te envia ese mensaje.
Similar problema se presenta en varias marcas y modelos, por lo que aqui puede obtener mayores detalles (con videos incluidos): Lens Error when turn camera
Suerte (recuerde calificar esta respuesta).
