Oster digitial toaster oven display does not light up, buttons and knobs do not work, can this oven be reset, if so how?
I found one of these on the curb. Took it home, and it was completely dead as you described. Took it apart, and there's a thermal fuse mounted above the convection fan that had blown. According to the data sheet, the fuse blows at 240C, but even if it never sees that temperature it will still fail eventually if exposed to high enough temperatures. The fuse is mounted against the chamber where it will get hot, so basically these ovens are designed to have a finite lifetime.
Anyway, long story short, you can buy replacement fuses online for a few bucks. It's a SEFUSE SF240E. Or just bypass the fuse. Keep in mind that the fuse is a safety feature that will kill the oven if it overheats, so keep that in mind if you decide to bypass it.
SOURCE: broken timer knob
I had the same problem where the time knob broke. I filled in a claim form on the Oster Website and they answered within 3 days saying the timer knob was discontinued and no longer available. They proposed to replace the whole toaster-oven with another model 6073-33 which I received last week. I've to say that their customer service was amazing.
SOURCE: OSTER TOASTER OVEN --- TIMER TWIST KNOB BROKE
Need to replace all the knobs on the Euro-Pro Toaster oven model T0160. Please let me know where I can purchase these knobs.
SOURCE: Oster Toaster Oven 6232 replacement parts?
Write to Oster and they might give you a new one depending on how old it is
SOURCE: Oster Toaster Oven Model # 6192-33
SOURCE: Oster 6232 toaster oven.
trying to find a solution for a broken knob, i discovered that there aren't many decent options. so i took it upon myself to find one. my father actually recommended that i post the solution, seeing that there were so many with broken knobs. now this works on the timer knob on an oster 6232 toaster oven. it may work on the other knobs and possibly other models, but i cannot confirm that. the plastic stem of the knob that slips over the medal stem of the timer had broken. i crazy glued it back together and knew that there was no way in hell it would hold up with just glue. sorry for the lack of pics on this part. with the broken piece glued back in place, i went to home depot to find something/ anything that would securely slip over the stem of the knob. i tried all sorts of tubing. copper, pvc, steel and found nothing. in the plumbing isle with all the brass fittings and compression fittings, i found an "ander-lign compression nut" 5/8" OD w/ insert. part # A-304 961-P.
all you need is the brass flanged insert. if you can find it without the nut and compression ring, then more power to you. after buying this, slip the piece over the knob stem flanged end first. i used 5 minute opoxy to ensure it would stay in place.
i then used a cone shaped diamond bit in my dremel tool to notch out the two sides of the knob.
just cut the brass down enough to match the notches in the stem of the knob.
and there you have it. sorry for the 2 blurry pics. hope this can help some of you.
