post a solution and is there a booklet available?post a solution and is there a booklet available?
AnonymousMay 06, 2009
same fault on mine E1 but don't know what it means do I have to get a man out to sort it ! (kenwood dishwasher kwd243a)same fault on mine E1 but don't know what it means do I have to get a man out to sort it ! (kenwood dishwasher kwd243a)
You can't post conmments that contain an email address.
The machine still thinks it has flooded hence the pump continuing to operate. You have already checked the float and microswitch. Make sure the microswitch has actually switched off. If the switch shorted internally, it may be in its closed position and still causing it to think the machine has flooded. It should be open circuit when no water is present in the base. It could also be possible the pressure switch (water level switch) is faulty and reading a full of water situation, when the machine is actually empty.
An E1 is a control board error. Sometimes it can be soldered at the heat element relay which get hot often and can melt the solder ion the board. It is fairly easy to replace a control board.
The dishwasher still has water in it. Lean dishwasher back at least 45 degrees and water should drain out through overflow pipe. It could be caused by the dishwasher not being level. Otherwise from reading reviews online it seems to be a common fault with this dishwasher and lots of people have returned and purchased different.
