When I first tried to set a WPA password this did not work. So I updated all firmware but the problem persists. Password appears to set but my Nexus 7 still sees no security on my wireless network
SOURCE: D-Link 514 Secure Networking
To read the manual you will need Adobe Reader (free)
If needed click the Get Adobe Reader button on the following link
http://www.adobe.com
The DL-514 has several revisions use the pictures and the label on the router to get the revision for your router. Click on the picture and get the Product Manual (from the left column) -- you will need it to configure the router.
http://support.dlink.com/products/revision.asp?productid=DI%2D514
Looking at the page and manual for the A and B versions of this router which will not match yours WEP was originally supported adn WPA can be added with a firmware update on the page. -- you will need to tell me the revision for your router so I can gather the correct information for it to assist. Please report that in a comment to this issue.
WEP or WPA are kinda like passwords but you only enter them once into the router and once into each computer to access the network. The router has an administrative password that should also be set but that only stops people from changing the router configuration like we will do shortly.
I am looking forward to your response and pursuing the next steps in this process.
Once you get me that we will proceed to the next steps.
SOURCE: Username & password
yes you can change the ssid
do to device then select adminstrator then change it username and password
SOURCE: Wireless security not working on my D-Link DIR-655
- Log on to the configuration page of the router
- Go to Manual Wireless Network Setup
- And Change the Channel width to different one
SOURCE: D-Link DIR-625 can not broadcast wireless continously
LOOK AT BACK OF LINK BOX FOR A SMALL HOLE WHEN FOUND TURN POWER OFF ON BOX PUSH TIP OF PEN INTO HOLE THEN TURN POWER BACK ON THIS WILL RESET MEMORY
SOURCE: We just bought a new emachine, Acer E627, with
WPA is not very stable and I have seen many problems with this. Simply change router setting to be configured with WEP and use a good strong password in hex 0-9 and a-f . WPA is horrible any way, and who the heck is gonna sit out side your home to hack it? It is not a WIN 7 problem but more like aging encryption.
Step 1:
Access the router's web-based setup page by opening a web browser. On the Address bar, enter your router's local IP address then press [Enter].
NOTE: The default IP Address of Linksys routers is "192.168.1.1". For instructions on accessing the web-based setup page using a Mac computer, click here.
Step 2:
When the login prompt appears, enter your router's Username and Password.
NOTE: The default password is "admin" and
the Username field is left blank. If you have set a password before
but forgot it, you need to reset the device. For instructions on how to
reset a Linksys router, click here.
Step 3:
On the Setup page, click the Wireless > Wireless Security.
NOTE: If some of the tabs are missing in the web-based setup page, upgrade the firmware of your router. For instructions, click here. You can also set the wireless security of your Linksys E-Series routers with Cisco Connect. To learn how, click here.
On the Wireless Security sub-tab, there are various wireless security options that you can choose from.
However, as mentioned earlier, the three most commonly used security modes are WEP, WPA Personal (or WPA Pre-Shared Key), and WPA2 Personal. The instructions below will show you how to set up the following security modes. On the other hand, the WPA2/WPA Enterprise Mixed Mode, WPA Enterprise, WPA2 Enterprise, and RADIUS security modes will only work if the router is connected to a RADIUS server.
Setting-Up the Wireless Security
Wired Equivalent Privacy (WEP)
WEP can be a 64-bit key with 10 hexadecimal digits or a 128-bit key with 26
hexadecimal digits. This encryption will prevent other users from
connecting to your wireless network. It will also protect your wireless
transmissions from being accessed by other users.
NOTE: In case the screen on your router's web-based setup page looks different, click here.
Step 1:
On Security Mode, select WEP.
Step 2:
Under WEP Encryption, select 40 / 64-bit (10 hex digits) and enter a unique word in the Passphrase field.
NOTE: The 128-bit key uses a higher
level of encryption compared to the 64 bit WEP. It uses a 104 bit (26
Hex Character).
Step 3:
Click the Generate button and copy the string of letters and numbers displayed in the space provided for Key 1. The Key 1 contains the wireless password.
NOTE: You can also create your own Wireless Password (Key 1) given that it is in hexadecimal format. The hexadecimal system consists of the characters 0,1,2,3,4,5,6,7,8,9,A,B,C,D,E, and F. You can only choose 10 characters (in any given order) from that set.
Step 4:
Click .
Wi-Fi Protected Access (WPA) is a
Wi-Fi standard designed to improve the security features of WEP. WPA is
stronger than WEP encryption. PSK and PSK2, the two types of WPA, give
you a choice between two encryption methods: the Temporal Key Integrity Protocol (TKIP), which incorporates Message Integrity Code (MIC) to provide protection against hackers, and Advanced Encryption System (AES), which utilizes a symmetric 128-Bit block data encryption.
NOTE: For older versions of Linksys routers, WPA Personal is also referred to as WPA Pre-Shared Key. Refer to the image below for an example.
To set up WPA Personal on a Linksys router, follow the steps below:
Step 1:
On Security Mode, select WPA Personal.
NOTE: If you are unable to find the WPA Personal or WPA2 Personal in
the list of choices for the Security Mode then you might need to
upgrade the firmware of your router to its latest version. Upgrading
the firmware can fix the bugs of the previous version and update its
other features.
Step 2:
Enter your Passphrase.
NOTE: The Passphrase must consist of at least eight characters and is case-sensitive.
Step 3:
Click .
