The HDMI ports quit one after the other. Can they be repaired or replaced?
SOURCE: HDMI ports do not work after lightning storm
Probably not, but your insurance should pay if you have a renter or homeowner policy.
SOURCE: TELEVISION - PS3 AND XBOX HDMI COMPATIBILITY
You have to use the scart connector for on screen menu settings. Go to the video option and enable HDMI and/or match resolution output to your set.
You did not mention the model of the TV so here is another scenario,
Just because the TV is 1 year old doesn't mean that it is a 1080p capable, you could have set the HDMI resolution settings to 1080p and you will not get any picture if your set cannot process the information.
SOURCE: Westinghouse 1080P 42" LCD TV - HDMI stopped working
Just reset the TV found out how here: http://www.danielcoburn.com/uncategorized/westinghouse-1080p-42-lcd-tv-hdmi-stopped-working-fix/
Hold the power button for 10 seconds.
I know this is late, but this happens frequently. If anyone else has the same problem try unplugging the TV for 60 seconds. Plug it back in and then hold the power button down for 30 seconds.
That will reset the TV.
You should see the Westinghouse logo come up and the HDMI should work. This has happened twice with my TV in 1 year.
SOURCE: Sony Bravia television hdmi stopped working
Installing a new software update will this issue. All you need is a compatible USB flash drive. Go to support on Sony.com. Look up your tv model and if there is an update, just follow the instructions to install it yourself. I have a KDL-46S5100 and this worked great. The download and instructions page I used was : http://esupport.sony.com/US/perl/swu-download.pl?upd_id=4769#install
