Brewed a pot of coffee machine turned off and will not turn back on.
SOURCE: Cuisinart COD 4000 coffeemaker
Just a comment; most of the coffee maker failures are caused by the premature failure of a thermal fuse that is intended to prevent fire in case the main heater doesn't turn off as it should. Unfortunately, most of these parts come from China and are very poorly made so the point at which they 'protect' is pretty unpredictable, many of them failing at a much lower temperature than necessary. The second most common failure is the thermal switch that cycles the main heater element; these are bimetallic switches that grow 'tired' and the point at which they open and close again gets wider apart until it can take an hour for a 12-cup pot to finish brewing.
SOURCE: Self clean feature on coffee pot
http://www.cuisinart.com/share/pdf/manuals/dcc-1200.pdf. This is the manual of the product
SOURCE: Cuisinart DCC-2000 12-Cup Coffee Maker shuts off after brewing
Turn the function knob to Auto Off
Hold down the hour button til you see the clock display blinking
you can then use the Hour and Minute buttons to program how long you want the coffee maker to stay on.
You can choose from 0 minutes (seems to be what you have it set on now) to 4 hours.
SOURCE: Cuisinart coffee maker turns on but will not brew.
Well, you could try unplugging for an hour. Sometimes that helps, but these have been having a lot of problems (but don't ask their customer service that, they can't admit it but I'm pretty sure they all know it!). I would say call customer service anyway if it's under 3 years old (800-726-0190) after you've unplugged it and let them know what's going on (model and serial # are both located on the bottom of the unit, stamped in the black part). If it's under warranty they can offer you a replacement and from what I hear Cuisinart has been getting in new coffee on demand units (like the one you have) that have fixed the problems. They're on back order right now though, so there will be a wait. Other than that, I would say you don't have many options, unless the store is willing to take it back, because this one is pretty much a goner. Not the first time I've seen it. :(
SOURCE: Coffee Maker only brews 1 cup at a time
Hello. I just talked to Cuisinart and they recomended running a solution of 1 part vinegar and 3 parts water through the brew cycle,then a full pot of plain water to rinse, to remove hard water deposits. The phone # to Cuisinart is 1-800-726-0190. I hope all works out for you.
builderdale
