Test ignition coils with multimeter
Here's a link to the coil testing.
i want to test my ignition coil first before buying a new one. my pathfinder is not equipt with distributor. i have individual coil for each spark pug
Hi Jimmy,I am looking all over internet for coil testing for your vehicle;check what this one site has said,but I will keep looking.Japan Ignition Coil 08/04 - Nissan Pathfinder 4.0 4WD VQ40DE Left/Right 6 per engine Direct Ignition Coil Although not absolutely required, Nissan is now recommending that if one coil has failed, all six should be replaced to prevent comebacks and premature activation of the "check engine" warning light. Read more:http://www.redlinemotive.com/replacement...
Here are some ignition coils if you decide to replace themhttp://www.ebay.com/itm/Nissan-Infiniti-...
SOURCE: Hi, 2006 Nissan Sentra, The car won't start, I
I have an 06 sentra as well with a similar problem. Just pop the gear shifter into neutral and then turn the ignition. The car should start. It always works for me.
SOURCE: p1320 runs smooth no misfire
These engines had a lot of problems with coils, most people just end up replacing all of them. You may find them a little cheaper online. There was a bulletin for broken or worn wiring inside the harnesses that go to the coils so you should carefully check back along the harness to each on, especially where the harness might move when the engine torques over.
Dave
Fig. Fig. 1: Engine ignition coil harness connections-3.0L and 4.0L engines
Fig. Fig. 3: CKP sensor wire harness connections for the 4.0L (VIN X and E) engines
If there is power and both the coils and sensor check good, replace the ignition control module.
