Sony BRAVIA XBR KDL-V26XBR1 26 in. LCD HDTV Logo
lynda keen Posted on Dec 30, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
No picture, only colored vertical lines
At first we had a frozen picture with sound and vertical colored lines, now no picture only vertical colored lines
Lisa Demont
Level 2:
New Friend:
  • Expert 43 Answers
  • Posted on Jan 21, 2013
Lisa Demont
Expert
Level 2:
New Friend:
Answers
43
Questions
0
Helped
46053
Points
113
Settings. It sounds like the convergence. It needs to be adjusted. Have had this problem before. A lot of people actually throw there TVA away because they have this problem and they think its broken, when its usually just a simple fix of adjusting the convergence. You have to make sure the little box, on the convergence settings is in the middle. Hope it fixes ur problem. :)
2 Related Answers
Anonymous
  • 320 Answers
  • Posted on Oct 18, 2008
SOURCE: Multi colored vertical lines
Probably you need an optical block, but it would take a tech looking at it to be sure
Anonymous
  • Posted on Dec 28, 2009
SOURCE: screen has color. but no picture.
Unscrew the cable off the cable box on the out to TV end, then screw it back on. You may also try a different type of cable, like HDMI or component cable.
No picture just vertcal colored lines and sound
What is the exact model number to your Poloroid TV?
Magnavox 32MF337B/27 power supply works and like another writer when power is turned on the audio works the channels change and you can tell that all remote and on set keys work, but no picture except an...
hi i have a 50" magnavox that has a problem, i was looking at several websites and i find out the dirfferent posibilities.
in your case i have 2 posibble answers.
1) negative image
tv turns on and shots down in 2sec
flashing pixels on screen
dark image
has sound but no video
screen goes black and then return to normal picture
vertical color lines on screen no video
vertical color lines with video
vertical bars on screen
horizontal lines on the image
picture goes red after while
IT COLUD BE (X or Y or Z SUSTAIN BOARDS )
2) just left part of screen working
just right part of the screen is working
vertical and horizontal lines on screen
part of screen not working
some functions not working
no video but has sound
functions not working at all
IT COULD BE (LOGIC CONTROL BOARD)
TErry HerreRA
1helpful
No picture vertical colored lines blinking
im afraid to say your display has gone contact funai they should be able to help you replace the display.
2helpful
2answers
Phillips 50 inch Plasma
Philips 50 inch plasma tv no video but has sound
Picture problem
Aside from the parts you mentioned check the vertical connection to the yoke (usually yellow and green wires), it may have a cracked solder joint or it could be burned. Also check the yoke for a broken vertical winding.
If the line is yellow with no other colors you may also have a bad color gun or drive transistor. If all color guns are working the line should be white.
2answers
Vertical color lines
Here is a picture of my TV problem, the green horizontal line is from the camera flash. thanks for the help.4d2ca33.jpg
Vertical colored lines on screen-no picture
It's definitely possible. I'd have it checked by a repair center for something like this.
No picture on 42" plasma TV.
take your tv to a tech the tv is having problem in the color circuit and the vertical circuit.
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
