Manual
SOURCE: eMachine W3052 with FIC K7MNF-64 Mobo
I did just solve all my problems with my own FIC K7MNF-64
Stop error: 0x0000007b / may be caused by attempting to load XP HOME
I've not determined exactly why attempting to load XP Home will cause
error 0x0000007b on the FIC K7MNF-64 , but it does , and it's a situaion not covered in the microsoft artical on it.
From what I can gather XP pro was the offical operating sytem for the board which I've now loaded to mine , windows 98/ME can load to it without problem so that rules out a hardware issue on my end.
eMachine T3395 or W3050 shipped with the FIC K7MNF-64 in them.
Drivers can still be obtained from eMachine for the board as of 8-26-2008
but for XP pro only from what I can see. you may need to hunt around for
98/ME drivers , even if you manage to get 98/ME drivers you will most likely still have a PCI Universal Serial Bus issue so best to load XP pro if possible.
I hope this information saves some people alot of time.
May the nForce2 be with you , always.
SOURCE: fic k7mnf-64 motherboard socket 462
Power is not going to the board. Check the power supply cables going to the board; most use a big 20 pin connector & a 2nd 4 pin connector. Make sure both are plugged into the proper spots then retry boot. Should see a green light on motherboard if power is properly set up. Hope this helps.
SOURCE: what is max memory for fic k7mnf-64
Supports up to 2 GB RAM 266/333/400 (aka: PC2100/PC2700/PC3200)
SOURCE: I need a K7MNF-64 Motherboard 102732 manual. Can
http://www.brothersoft.com/downloads/computer-manuals.html this site will tell you how to use something http://www.easyhelpguide.com/manual/ASRock.html http://www.easyhelpguide.com/manual/index.html http://www.easyhelpguide.com/manual/index.html here are many manuals and guides on how to use things hope this helps you
you will have to type in the motherboard in the top search tab
hope this helps you
