Turned it on while leaning to see if pump was working. Washer turned of and now it is dead.
SOURCE: I have a Fisher & Paykel GWL11 washer. I
I have the same problem...looking for service technicians manual or some way of troubleshooting.
SOURCE: Fisher&Paykal GWL11 washer. I replaced
Hi, turn the machine off at the wall and do not use the machine until it is repaired as the control module might short out and then the repair will be expensive.
Now bail some of the water out of the machine with a small bucket or pot, enough so you lean the machine back against the wall so you can look under the machine without the water pouring out onto the floor.
Now when you can look under the machine look to the front right and you will see a black fan.
This is your pump. Check the pump for corrosion with a torch.Turn the fan a few times to see if it is jammed. The fan should turn freely.
The pump maybe jammed, blocked or is faulty which will not make it work.
And if the fan is turning freely with a good fuse in it and it is still not pumping, am afraid it is faulty and needs replacement...
SOURCE: GWL11 washer diplay won't light up or power on. drain pump leaked, replaced both, still nothing
your main board is out very come with a bad drain pump the new pumps and boards come with a fuse to stop this problem. water hit the pump and shorts out the board
