It keeps dropping connections to the internet (wireless)
SOURCE: Belkin N1 Router connection drops when phone rings
You may have a phone line connected from the modem to a wall outlet. Count the number of cables coming out of your modem - you should have only three: the power cable (connects to the wall), Cat 5 (also connects to the wall), and ethernet (running from the modem to the router).
SOURCE: belkin f5d7132uk keeps disconnecting
have you tried turning off Wireless Zero Configuration
Go to Start | Control Panel | Administrative Tools | Services
Scroll down to Wireless Zero Configuration, right clicking properties, and Stopping the service in Service Status.
Do this on all the Pcs,
If this solves the problem, turn off Wireless Zero Configuration permanently by changing Startup type to Disabled
SOURCE: belkin wireless router
Your Belkin router is normally configured to get a dynamic IP Add from your Internet provider unless otherwise configured. Most ISP's network where clients/subscribers connect (through DSL) has a DHCP server that hands out this IP adds. If your router keeps on changing its WAN IP add, it may presumably be because:
1. Your router keeps on rebooting or powering on/off and everytime it turns on, it is given a new IP add;
2. Your ISP's DHCP server keeps on renewing its lease on the IP add given to your router.
Corrective measures would entail:
a. Do a full hard reset of your router and go through the installation setup again. Of course this would revert all settings/configuration to factory default; and/or
b. Contact your ISP and explain your concern.
In some cases, the router's MAC address has an issue that the ISP's DHCP is keeping a hard time recognizing it. this can be corrected with a firmware update.
Hope this be of help/idea. Pls post back how things tunrs up or should you need additional information.
Good luck and kin regards.
SOURCE: wireless ready laptop not getting connected to internet through belkin router
You may want to check if the wireless switch is "ON"
on the laptop most wireless ready laptops has either a
button or toggle switch to enable the wireless radio..
if it's already enabled and you still cant connect to
the wireless network,try changing the wireless channel
from the router.
SOURCE: router disconects from modem-Belkin router/Wildblue modem
hi,
try to chk out the firmware of the router. in most of the cases firmware are the major problem for the disconnection of the connection if the device has been purchased a while ago. visit ur belkin website and look for the firmware for your router model no.
if the device is new then try to decrease the mtu size and temporarily disable the firewall of the router
gud luck
thanx and regards
sukhiii
