RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
Anonymous Posted on Jan 17, 2009
TV green light comes on and then shut off. TV won't come on.
RCA 52inch HD52W59 do i need to take the panel off the back to use blow dryer trick.
TONY BIGNELL
Level 2:
  • Expert 147 Answers
  • Posted on Jan 19, 2009
TONY BIGNELL
Expert
Level 2:
Answers
147
Questions
Helped
43112
Points
326
Which blow dryer trick?
My rca 52inch rear projection tv would shut off then come back on know it won,t come at all is it possable it is a bulb help wayne
this model does not use a bulb, but has 3 picture tubes. Most common problem for this is bad solder connections under the high voltage transformer.
My RCA model # HD52W59, power on and shuts down without coming on. Green come on then shuts down. No picture or sound.
The set is in shutdown because of a problem inside, this model has the three strikes and your out, it will try three times to come on and then latch down. It likely needs a shop repair of some kind.
2helpful
2answers
When turning TV on, Green Light comes on and then a fizzy, static sound coming from the bottom side of tv. then the green light goes off and then I smell like a burnt electrical smell. Can anyone tell me...
back or front of tv .... this could be a blown tube if coming from front. from back there is a high chance this is a blown flyback. i have also seen a blown capacitor that blows a hole in the board. be careful leave unpluged.
Rca hdtv 52inch will play fine then picture goes black but still has sound.. after a few mins.picture will come back on , and will play fine could last all day or may go out again in a few mins.
My tv is relatively new, but the bad thing is that I had an old; big screen tube type rca model; home theatre, that was heavier than a car, and it went out, due to the cracking and popping sound, off sometimes, and back on.
What is strange is the new tv now, the hdtv, light weight, about five years old, is doing the same thing. Actually, now, the power will not even come on. The lcd green light in the front goes on and off.
Take no offense, but I thought I would not have these problems anymore. What do you suggest?
I have a 52inch rca projectin tv model hd52w59 i
Ur convergence it dead,U know how to solder?Buy a covergence kit,replace what in that kit.Tries these Websites,Tv Repair World.com,Ebay.com.
4helpful
2helpful
2answers
Rca d52w14 hit power green light blinks three times wont come on
could be power supply problem or high voltage problem. check caps in main power supply first.look for caps that have tops puffed up ususlly three or four.....
RCA 52inch Model R52WH77 HDTV
may i suggest reading the ariticle the fl231 problem in my tips and tricks section of my profile. YOu MAY have a 5 dollars 30 minuter fix. Determine if you have the convergence option under the setup option of the customer menu. if you dont then congratulations you have a simple fix. i you do have the convergence option and the autoconvergence then you might have other problems. and will have to troubleshoot further. If so ill talk you through some more. THIS set has NO stk convergence ics. my feeling is the fl231 which i see alot on this perticlar model at the shop
RCA TV Will Not Power On - Powered Off Suddenly
I have the same problem. Just Monday it started, Green light blinks but nothing comes on. Any suggestions?
2helpful
Rca hd52w59 problem
Sounds like you have a high voltage shutdown. A flyback or a crt is arching.
Top RCA Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
