I have the same problem after the carb rebuild as I did before the rebuild. The engine dies a few seconds into the high spped run. I have tried adjusting the high speed idle to no avail.
SOURCE: Poulan chain saw after carb rebuild.
Is thereadjustment somewhere on the saw
I think there is 2 .
SOURCE: Model 3400, runs on idle but not at full speed,
I think like you it is running lean. Normally I would provide a link to the IPL (exploded parts list) for your saw but Poulan just locked the site for non-dealers. Please register your displeasure here http://www.poulanpro.com/node4020.aspx. IMO as an owner, you should have free access to these.
Sounds like time for carburator kit, HTH
Lou
SOURCE: 1635AK will not run in high idle
screw back idle and air clockwise fully let them 1 and3/4 turns out that should sort it check brake isint stuck onn aswell
SOURCE: The chain on my Stihl 034 runs even at idle. Is
There are three possible reasons for this, either the idle speed of the engine is too high ( unscrew the idle screw on the side of the carb ) or the bearing on which the sprocket runs has not been greased and the drum cannot run freely on it ( remove the side cover, turn the sprocket by hand, it shoud turn freely and not try to turn the crank ) or the clutch springs are weak, or have broken ( remove the side cover, remove the c clip and washer holding the sprocket on, and remove it, you will now see the clutch, check for broken springs, if the shoes can be readily pulled out by hand, the springs require replacment.
SOURCE: chain saw starts hard, have
Sounds like dirt in the carb. Pull carb apart and spray out real well with gum cutter or carb and choke spray. Be sure to remove the needle valve and rinse all holes and ports. Use COPPER wire, like a strand from automotive or speaker wire to run through each hole. rinse everything a few times
