Samsung NP300E4C-A02US Laptop Logo
Posted on Dec 29, 2012
No Wireless network in the Device Manager - Samsung NP300E4C-A02US Laptop
Anonymous
Level 1:
New Friend:
  • Contributor 10 Answers
  • Posted on Dec 29, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
10
Questions
Helped
4463
Points
41
Maybe this will help Open up your device mgr.
In Devise Mgr -If everything is properly detected you'll see all +'s next to each of the device categories with no "Other devices" listed as shown in the example. However, when problems do occur you'll be presented with one or more of the below errors.
When a device has a yellow circle with an exclamation mark or found under "Other devices" this is an indication that the device is conflicting with another hardware device or the drivers for the device are not installed properly.
Double-clicking and opening the device with the error will present you with an error code.
What to do
Remove all devices with exclamation mark and any "Other devices" from Device Manager by highlighting them and pressing the delete key on the keyboard. Once they've all been removed reboot the computer and allow Windows to re-detect the devices.
If after rebooting the computer the Device Manager remains the same Windows is not installing the devices because it lacks the proper driver support. You'll need to download the latest drivers for that device.
MY HP PAVILLION'S PORTS DON'T WORK, INTERNAL WIRELESS DOESN'T WORK AT ALL
Most of the laptops those are the common issues Wireless are not working, what i suggest is try to renistall the Driver for the wireless card then check it in the Device Manager, if it doesn't show in Device Manager the wireless card could be faulty.
How to check Device manager.
Start->Control Panel->Device Manager
Inside Device Manager look for Network Adapter and check if your wireless card is detected.
No wireless adapter
Have you check the wireless card under the Device Manager?
Under Device Manager look for Network Adapter there will be sub folders under network adapter look for the wireless device. If its not showing it means that the Device is not working. If you want to make sure try to reinstall the Operating System and after that check again the Device Manager.
1helpful
2answers
The capability of your network adapter does not match the requirements of the network this is what it says when i try to log onto our new wireless router? please halp......
To correct this issue visit Device Manager by going to Start, then right click Computer, choose Device Manager. Once you are in the device manager click the + next to Network Adapters. Find your wireless network adapter, right click it, and choose uninstall. Once you uninstall the drivers, right click and choose Scan for Hardware Changes. This will then have your computer re-add the drivers.
1helpful
2answers
Lenovo y430 wifi adapter not found in device
hi there, you wireless network card driver is probably not installed. check in control panel if your computer has detectde your wireless network card. got ot control panel then system then device manager and look for network adapters.make sure that wireless network card is installed there withot exclamation mark. if not present then reinstall the driver by using the driver disk that came with the system or going to the website http://consumersupport.lenovo.com. if installed, then try perssing Fn+F6 to enable/disbale your wireless card.
please let me know if you need more help.
Thanks
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
How do I tell if this card is wireless?
Ethernet Card adapter is a wired adapter but you can always check for wireless adapters.Go to device manager by right clicking on my computer->properties->Hardware->Device Manager. In device manager click the + sign at network adapters and check if it is written wireless under that then you have a wireless adapter.
Does my HP s7750 have wireless internet connection. if so how do i turn it on or if not do i need to buy a wireless usb adaptor
check the box that the machine was packed. if you find a antenna, then, your machine have wireless LAN.
to set up the Wireless
1 Click the Windows Start Button on the taskbar.
2 Type Device Manager into the Search box, and then click Device Manager to open
the Device Manager window.
3 Click Network adapters. Your WLAN device should be listed here. The WLAN
device may include the term wireless, wireless LAN, or 802.11.
4 Click the Windows Start Button on the taskbar.
5 Type Network and Sharing Center into the Search box, and then click Network
and Sharing Center
to open the Network and Sharing Center window.
6 Click Add a device to the network and follow any onscreen instructions.
For more information about setting up a wireless network:
 Click the Windows Start Button on the taskbar, click Help and Support, and
then type Setting up a wireless network into the Search Help box.
NOTE: If no WLAN device is listed, either your computer does not have an integrated
WLAN device, or the driver for the device is not properly installed.
Wireless networking hardware not functioning properly.
Check on Device Manager if it is working properly
Right-click My Computer-Properties-Hardware-Device Manager
Click on the plus sign beside Network Adapter and double-click your wireless card.
Check on the device status if it says it's working properly.
Try to disable-enable the adapter by right-clicking on it under the device manager window.
If it has a question mark, it is most likely driver issues so contact your wireless card manufacturer or PC manufacturer if the wireless card is built in.
Wireless connection disapeared from computer
Hello!
I am not sure exactly where you are checking for Wireless connections.
Anyhow, now a days we are hearing many Wireless adapter missing from Device manager issues.
Please get back to us with the Brand name of your laptop, OS installed.
Also check in Device manager for Wireless adapter.
Please follow these steps to open Device Manager:
1. Right Click on 'My Computer' icon on Desktop and choose Properties.
2. The System properties Window opens.
3. Click Hardware tab and then click the Device Manager button.
Expand + Network adapter and check if the Wireless adapter is listed there or not.
If it is not listed there, then the issue is with the Wireless adapter itself.
This is most comon issue in HP COMPAQ notebooks.
if you are not aware of the Wireless adapter under + Network adapters in Device manager, then get back to us with the complete information under + Network adapter.
So thatI can help you in better way
I have a lap top with a wireless card already installed, I purchashed this N wireless usb adabter to increase my wireless signal when in fact now I have less as now this adabter is acting as a wireless...
Disable The Inbuilt Card Under Device Manager and you will only have one Wireless network Connection
Right Click my Computer -> Properties
Click on the Hardware tab
Select Device Manager
Expand Device Manager
Under that right click on the inbuilt adapter and select Disable
Wireless Lan on HP Pavilion M1000
Surely you can find out if you have a wireless network card installed . For this you can goto device manager and under network adapters look for any wireless adapter.
Heres How you check device manager.
  • Right-click My Computer then select Properties
  • Select the Hardware tab
  • Click the Device Manager button
  • Alternative solution: invoke devmgmt.msc
  • Alternative solution #2: Device Manager is part of the Computer Management, which also includes Event Viewer, Services Manager, Disk Management, as well as many other things. Right-Click My Computer then select Manage to start Computer Management, or invoke compmgmt.msc.
Picture of device manager and random wireless adapter
http://www.cisco.com/warp/public/102/wlan/xpleap_02.gif
Also I am not too sure about what system you are using and whats the operating system you are using.
Top Samsung Computers & Internet Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Jean Thiebaux
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
