No...I doubt thats the problem...The networks were showing up the first time we got the tablet...they just disappeared after a couple of days...I also have a Coby 7" tablet that has the same specs and it recognizes the router so I believe its got to be something elseNo...I doubt thats the problem...The networks were showing up the first time we got the tablet...they just disappeared after a couple of days...I also have a Coby 7" tablet that has the same specs and it recognizes the router so I believe its got to be something else
You can't post conmments that contain an email address.
you will need to set up the wifi first , there is a spot in the setup screens that says wifi , go to this and expand it by clicking on it , this will show a list of avail networks (there could be more than one) select yours in the list , a prompt will show up (enter network password ) you must enter your network password exactly as its in your router (or coffee shop router) and press enter when done , it will prompt back with connecting " when its done it will go back to previous screen , make sure your main prompt for wifi is still on then open your browser and enter a desination it should work , I will tell you this model is very picky about signal strength and wont connect unless you have least four bars .
Press and hold the wifi option and then search for the network, else turn off both the devices and restart the router first, let all the lights come up and then turn on the tablet.
To delete a wifi network from an Android device first open wifi settings and the list of networks.
Touch and hold the network you wish to remove.
An option will pop up to "forget network" this will delete it from memory and it will no longer connect to this network.
Assuming you already know that a password isn't the issue and you know how to handle connecting to a password protected network...
Does your router have mac address filtering turned on? Maybe it's rejecting your tablet because the tablet's mac address list doesn't include the tablet's mac address.
You connect your Nextbook to YOUR WiFI HOME NETWORK (not the Internet) FROM THE NEXTBOOK, not from the laptop. On your Nextbook, go to Settings then Wi-Fi. If your Nextbook is already connected to your WiFi home network you will see the network's name there and you are done. If it is not connected, a list of available WiFi networks appears. Tap on the name of your home network and it will connect to it. If your network is password-protected, you will be asked to enter it.
Ensure that Wi-Fi is on. When you see a green check mark next to the Wi-Fi option, Wi-Fi is on.
Choose a wireless network from the list. Available Wi-Fi networks appear at the bottom of the screen. When no wireless networks are listed, you're sort of out of luck regarding wireless access from your current location. Optionally, type the network password. Touch the Password text box to see the onscreen keyboard. Touch the Show Password check box so that you can see what you're typing; some of those network passwords can be long. Touch the Connect button. You should be immediately connected to the network. If not, try the password again.
Step 1Ensure the Wi-Fi and Low Power button located on the top of the device is not in the Off position. This will completely shut off your Wi-Fi adaptor and prevent you from connecting to the network.
Step 2Press the power button on the left side of the device and allow the Pandigital Novel to detect local network connections. If you can't find a local connection, you may be out of range and should move closer to the wireless router until the device detects the network.
Step 3Tap the name of the Wi-Fi network from the provided connection list. If the network has a lock icon next to the name, this means you will need the network security password to log in.
Step 4Enter the security password if prompted, and then tap "Connect."
Step 5Tap the "Next" button to reconnect to the Wi-Fi connection.
Step 6Tap the "Web" button from the main menu if you are attempting to connect to a public hotspot. This will launch the Web browser where you can enter any log in information required to obtain an Internet connection at the hot spot.
not to be mean but often times with those little cheap tablets (I have had a few) the wifi is picky due to cheep part and software(the device).here are some common problems.Does it support the type of network your trying to connect to?is your network key too long? some device dont like itis you network name too long? is your router blocking access?(firewalls, filters,port forwarding, client limits)are you with in 10 feet of the router, wifi on tablet can be limiteddo other device connect to the internet via this methoddo you even have a wireless network of you own?make sure wifi is powered on?hard reset devicethe list of what the issue could be is infinite-Good Luck.
I don't have a Cruz Reader in front of me so I'm going from memory on android devices.
menu button->settings->wireless & networks
make sure there's a check mark next to wifi and then select wifi settings.
here your available networks should be listed. Select the network you would like and use the on screen keyboard to enter the security key if applicable. Select connect and the reader should connect to the wireless network.
Hope this helps. Let me know if you have any other questions
This
is normal. To save energy, the ARCHOS always starts up with the WiFi
set to off. You must manually use the Fn-F3 keys if you want to
activate the WiFi connection.
I cannot connect to the Internet over WiFi, what's wrong?
Make sure that your WiFi is activated. This can be turned on and
off with the blue function key pressed down and then the F3 key. The
blue WiFi indicator just below the touch-pad will light indicating that
it has been turned on.
My WiFi router/modem is on and working, but it does not show up in the list of wireless networks. What's wrong?
It could be that the WiFi modem/router is hiding its SSID. This is
done for security purposes sometimes. You can either change this on the
WiFi modem/router (see its instructions) so that it broadcasts its SSID
(and then you'll see it in the list on your ARCHOS 10) or you can go
into the advanced settings of the Wireless Network Connection screen to
the Wireless Networks tab and 'add' a new connection. You will need to
know the SSID name and its other connection parameters.
