Question about eMachines W3507 PC Desktop
CAN I RESTORE MY PC FROM THE BIO OR BOOT LOGS MY WINDOWS KEEP SHUTTING DOWN
When i turn it on it saids error windows shutting down
  • 2,878 Answers
Not sure what you truly mean, but you need an install disc. It could be a CD / DVD, USB, or even a hard drive partition.
Posted on Dec 28, 2012
6ya staff
SOURCE:
Laptop shutting down on its own and said problem event name blue screen
The 'Blue screen error is a common Windows OS error.
You can find the reason of blue screen....read more
To solve this error in your laptop.see......Fix this problem
Aug 29, 2012 | Microsoft Windows XP Professional for PC
System error E000 how do I fix it. I tried what it said in the instructions to turn it off for a while then turn it back on that didn't help. Canon NP6025 copy machine.
To delay the 3 second shut down and enable the technician to access service mode; open the front door and pull out the transport unit. Do not actuate front door microswitch. Press the service mode button, enter " * 4 * ", scroll to error clear and clear error code. Machine will automatically turn off power after clear. Power up machine and test.
If the power shuts down after error code has been cleared, the cause of the error has not been corrected. Correct cause of error code and clear error in service mode.
May 07, 2009 | Canon Office Equipment & Supplies
Boot error
Problem Solved: My MMP8567 screen read ''boot error shutting down''.
Everytime I plugged it in to the computer the computer would find it but then it would disappear almost immediately.
I downloaded the Updater program from Memorex but it couldn't find the player.
The directions from Memorex said ''Hold down the play button and plug in usb cable.'' 'Another set of Memorex directions said, ''Hold down the power button and plug in usb cable.'' Neither worked for me.
SOLUTION: I finally held down the LOCK/UNLOCK button and plugged in the usb cable. My computer found the player immediately and a software driver window popped up asking for a driver. I let windows search the internet and it found and installed the driver. The driver it was looking for was: ''player recover device class driver'' After windows confirmed it recognized my mp3 player I started up the Firmware update program and was able to update the player.
I tried to be clear and detailed. Good Luck ;-)
May 06, 2009 | Memorex MMP8567 MP3 Player
Power off issue for GX280
just run scandisk for your windows driver and check for any errors.
i once got this problem i just ran scandisk and some errors are found in the filesystem and they were removed
after that i have no prob shutting down my pc.
and if possible try to run a virus scan like avast or avg. etc.., this could take long if you have a monster harddrive and data.
hope this helps..
Apr 17, 2009 | Dell Computer Refurbished SYSTEM BOARD -...
I have a mmp8567 and it is giving me Boot Error Shutting down
Update the firmware. Download directly from Memorex site, Support section.
The directions from Memorex said ''Hold down the play button and plug in usb cable.'' Another set of Memorex directions said, ''Hold down the power button and plug in usb cable.'' Neither worked for me.
Jan 06, 2009 | Memorex MMP8567 MP3 Player
Memorex mmp8567 boot error shutting down
Nov 30, 2008 | Memorex MMP8567 MP3 Player
Computer not started properly
the window is corrupt try to repair the window with window xp
May 30, 2008 | Intel D845GVSR Motherboard
Pentax Optio 60 LENS
The same thing happened with my camera, I gave it to a freind for her husband to look at it. He said when turning on face the lens side down (to the ground) when turning off hold lens side up right (to the sky). this worked for mine. I don't know if he did anything else to it but when I zoomed I got lens error. I did what he said and it took several tries but it did work... please post if this helps you.
Dec 13, 2007 | Pentax Optio 60 Digital Camera
Computer will not shut down
You can try the Ctl-Alt Del keys to see if you can get the task manager to come up. If you can then try to shut down using that. If not then the only choice you really have is to manually power down and restart. Chances are pretty good Windows will clean up after itself and should boot backup. During the process if you receive any error messages or warnings document them. Windows may also prompt you for a hard drive scan, let it. Let us know what happens and please don?t forget to rate this post.
Apr 16, 2007 | Compaq Armada E500 Notebook
eMachines W3507  PC Desktop Logo
Top eMachines Computers & Internet Experts
Thomas F. Schneider
Ekse
Are you an eMachines Computer and Internet Expert? Answer questions, earn points and help others
