mid Archos M729B Android Tablet Logo
christine Posted on Dec 28, 2012
Where is the reset button for m729b tablet
Having trouble powering up and want to try resetting it.
jeff blowers
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Feb 20, 2015
jeff blowers
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
903
Points
The reset button should be on the top of the tablet and it should be silk screend on the back of the tablet as reset
Nextbook 8P won't reset. I have tried troubleshooting instructions with no result
you are having trouble resetting your Nextbook 8P. Here are a few steps you can try to reset your device:
  1. Soft Reset: Hold down the Power button until the device turns off, then turn it back on.
  2. Factory Reset using the Settings: Go to "Settings," then "Backup & reset," and finally "Factory data reset." Confirm the action and wait for the reset to complete.
  3. Factory Reset using Hardware Buttons: If you are unable to access the settings menu, you can try resetting the device using hardware buttons. To do this, you will need to follow these steps:
  • Power off the device
  • Press and hold the Volume Up button and the Power button
  • Release the buttons when the Nextbook logo appears
  • Press the Volume Down button to navigate to "wipe data/factory reset" and press the Power button to select it
  • Confirm the action by pressing the Volume Down button to select "Yes" and the Power button to confirm.
If none of these steps work, the device may have a hardware issue and it may be necessary to contact the manufacturer or a professional repair service for further assistance.
Why am I unable to unlock my Zepad so I can remove photo on screen?
You have to format your device by Hard reset keys directly.
Procedure is very simple.
1.Turn off your Tablet PC by pressing Power Button.
2. Press/Long Holding Volume Down Button OR Volume UP Button.
3. Then Press Power Button to Turn on device
after that you will see factory resetting menu just select factory reset the pres Enter Or Yes.
Thanks
MID model M729B can not get the tablet to respond to unlocking the screen
Here's a link to the manual:
http://www.mymidpad.com/M729B_User%20Manual.pdf
You need to do a hard reset which will wipe all data and restore the tablet to factory settings.
I cant remember my draw pattern to unlock
just make a factory data reset.
To reset you tablet manually. you have to
1)switch of your tablet
2)hold volume down button and power button at the same time.
3)wait for 10 sec and you will enter into boot menu.
4)there in the boot menu you will find option named Reset factory default settings/reset user data. select that option
5) wait for resetting......
6)cheers your done.
Need the stock rom for a mid 729b?
Can you tell me where you got the upgraded rom from, and have you tried downloading the firmware from the manufacturer's website? http://www.archos.com/us/support/support_tech/updates_fwm.html
1helpful
Forgot pattern to get in it
You will need to perform a factory reset.
- Turn off the device and wait 10 seconds.
- Press and hold the volume + button while powering on the device.
- Keep the volume + pressed until the Recovery mode starts (white screen).
- To move from one option to another, use the volume buttons. To select an option, press the ON/OFF button.
There should be an option to factory reset or erase your tablet.
How to reset the a teblet
Look on the bottom where the other ports are. The reset button is the tiny hole between the HDMI and headphones jacks. Use a paper clip ti reset. Make sure you feel the click as the button is really small. Cheers Keith
Mid model m729b
I have similar problem, my buttons on the right side including yjr start button have slipped inside the case and I can not restart the charged device, Can you help?
Pat Green, [email protected], 409-782-2572, thanks if you can help.
Mid m729b will not shut down
A bit late but FWIW, I had this problem. I eventually just moved any data I needed to a safe place & fully reset it.
To reset, hold the power button & volume up button simultaneously. It should boot to a screen that tells you what to do next. I think they ask you to keep holding the power button for a reset. Do that & you'll see a big old 3D Android figure & a blue progress bar. Give it a minute & it should eventually load. After that I got a screen that said it was "updating" & gave me a percentage countdown. It finally booted like normal to factory settings. All of my data was gone but it now turns on/off like it should.
Top mid Tablets & eReaders Experts
k24674
ADMIN Andrew
ADMIN Andrew
Are you a mid Tablet and eReader Expert? Answer questions, earn points and help others
