SOURCE: TRUE under counter FREEZER TU2-27F
Are both evaporator fan and condensor fan running?You stated that you topped off the charge.Assuming the charge is ok, the next thing to check would be the expansion valve.May not be metering the freon properly.A faulty expansion valve can trick you into thinking the unit is undercharged.It may be partially open and starving the evaporator.(Not freezing the water totally)You should have a even coating of frost on the evaporator coil when running.Hope this helps,let me know if i can assist you any further.
SOURCE: wiring daigram
Go to "truemfg.com". You can fill in your info on the home page and gain access to a 24 hour, on-line tech support. Worth a try.
SOURCE: I NEED A DIAGRAM FOR DEFROST SWITCH ON T-72 F TRUE FREEZER
Go to www.truemfg.com and it will take you to their web site. They have a 24 hour, ask a tech a question. I could not find any wiring diagram on your particular unit but maybe they can help you via their tech hot line.
Good luck and hope this helps.
SOURCE: TUC-48F undercounter -10 freezer, door heaters not heating
http://www.truemfg.com/catalog/servlet/com.apsiva.servlet.HomeServlet
Go to this True web site. It has spec sheets and manuals. Hope this helps you
SOURCE: need wire diagram how to install 3 N 1 start relay
The two stripped black wires connect to power.
Black tabbed wire to common.
Red tabbed wire to run.
White tabbed wire to start.
Looking at pins on compressor, read like a clock. Common clockwise to Start clockwise to Run
