Question about Motorola Mobility T305 Bluetooth Speaker For All Bluetooth Enabled Phones 98783
I need a pairing code for my motorola blue tooth headsent T305 to pair with my nokia 6500s
  • vipul_ldce_e Apr 28, 2009
    I need paring code for motorola Bluetooth headset S9 to pair with my nokia phone.
Thanks, the code 0000 for the T305 worked.
Posted on Apr 07, 2009
    Sniper:
  • 92 Answers
Your pairing code should always be 0000, if that is not it try 1111 and 1234 that will cover 99% of all the pairing codes used by the bluetooth companies
Posted on Jan 24, 2009
6ya staff
SOURCE:
I have a Motorola t305 speaker for car it won't let me pair it i put in pass code oooo it says it is right code but make sure device is ready and it is solid blue just like it says but still won't pai
I have found that you need to turn off the Bluetooth and the phone or what you are trying to pair with before you pair this will give it a plane start and it should pair
Feb 13, 2013 | Cell Phones
IPHONE NEED PASSWORK MOTOROLA T305 BLUETOOTH?
most blue tooth manufactures use a 4 digit pass code or pin\pairing code they are as follows 0000,1234,1111,or 9999 i hope this helps
Feb 22, 2011 | Motorola Mobility Bluetooth Hands-Free...
What does the pairing code look like on the T305 and where is it located
Most blue tooth device manufactures use a 4 digit pin or pairing code they are as follows 0000,1234,1111,or 9999 i hope this helps
Feb 20, 2011 | Motorola Mobility Bluetooth Hands-Free...
My nokia 3230 was unable to perform bluetooth operation
It all depends. When you want to connect a blue tooth to a phone, You will need to switch on the blue tooth device and the phones blue tooth you are pairing with.
When pairing both device, you will ask for pairing code, You four digit numbers(default code(0000). and pair.
After pairing both device, you detected paired, you can now use the blue tooth device with your phone.
there are no special code for pairing Blue tooth device.
Normal codes used are any four digit, four numbers you want to use.(0000, 1234).
Take care.
Nov 25, 2010 | Nokia 3230
Need password to connect to my phone. Motorola bluetooth H371
Hi,it all depends. When you want to connect a blue tooth to a phone, You will need to switch on the blue tooth device and the phones blue tooth you are pairing with.
Hope it helps..
Thanks for using fixya...
Oct 27, 2010 | Motorola Mobility H371 Bluetooth Headset
I have a nokia 2730. but the bluetooth is not working properly. whenever i tried it shows "sending failed" to any other mobile.
Hi,for the blue tooth to work, first you will have to pair the device you want to use with it. Without pairing the device it will work.
Take care.
Sep 25, 2010 | Nokia 2730 Cell Phone
My nokia 2330 classic doesnt pair with my parrot 3200 ls color. after synchrinsing them unable to get authorisation code
Take care.
Aug 16, 2010 | Parrot 3200 Ls Color Handsfree Bluetooth...
My bluetooth dosent work in my nokia 6600
But if it doesn't pair after you've tried the above, that means the blue tooth is corrupted and will need to be flashed to restore bluetooth back.
FORMATTING PHONE
Formatting a phone is the same as flashing a phone to remove VIRUS infections on phones.
You can use this link to flash the phone and remove any VIRUS infection on the phone.
Read and learn more about flashing and how to flash a phone on this link.
unlocktotalk.com/UnlockCodeInstructions.htm),
Take care.
Take care.
Jun 30, 2010 | Nokia 6600
Cellnet Pico Bluetooth Headset wont connect to nokia 5800
Take care.
Jun 10, 2010 | Cell Phones
Motorola Mobility T305 Bluetooth Speaker For All Bluetooth Enabled Phones 98783 Logo
844 people viewed this question
Top Motorola Mobility Cell Phones Experts
Lawrence Oravetz
Vernon Taylor
Harrie
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
