Projector i have a sharp notevision xr-1s projector and it heats up really fast and then shuts off because the temperature gets way to high, what is my problem or how can i fix it?
Just recently my xr-1s has been shutting off with only about 5 minutes of operation. The temp symbal comes on once it shuts down the only way to get it to power up again is to disconnect and reconnect power cord. then the same happens. I cleaned out any possible debris from the inside and it still does it. its is rarely used as it is in our family room in the basement (which is climate controlled. I am at odds. Just recently my xr-1s has been shutting off with only about 5 minutes
My cooling fan works and i have the exact same heating problem. My lamp only has 195 hours on it. What gives?My cooling fan works and i have the exact same heating problem. My lamp only has 195 hours on it. What gives?
I also have this problem. After 5 to 15 minutes the lamp goes off and the lamp light goes red. Have to shut down and restart and then same thing happens. Cooling fan works fine.I also have this problem. After 5 to 15 minutes the lamp goes off and the lamp light goes red. Have to shut down and restart and then same thing happens. Cooling fan works fine.
Its not possible without remote.
If you wish to get some details; check the site linked here. Pull up older posts. http://electro-medical.blogspot.com/
if the line has a hazy edge, it may be that the light tunnel is collapsing or the dlp wheel needs to be replaced. if it is hard edged, it may be the dlp chip is bad.
the power supply is bad and need to be replaced. you can get the part and do it yourself, or send it to a sharp service center. either way, try av solutions in ny. they're really good. www.avsolutionsny.com
I also have the same problem. Has anyone had any success as how to fix this?? PLEASE HELP!
