I want to take pictures, but I get the message "memory card full'. How do I remove old pictures from it? When I click on the trash can I get the option of Delete, but it's not highlighted. So how do I clean the card? Any assistance you can provide will be appreciated.
The best way to remove all pictures from the memory card is to format it. This wipes all data from the card and prepares it for further use.
Without knowing the model of your K-M camera I can't give you the exact procedure for formatting the card, but there should be a command somewhere in the menu system, probably under "Setup".
SOURCE: Memory Full Error
to use a memory card u have to check the manuel probably u have to buy an mmc card for storing pictures and videos as it is an sd card u have to first dormat it u can do it inside a mobile phone also
SOURCE: How do you delete all pictures simutaneously from Nikon L18 camera?
Hi - You can download the manual by clicking the link underlined in blue below:
COOLPIX L12
See page 88
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Informatica
SOURCE: Olympus 790SW 7.1 MP reads full 1GB memory card is full after 2 pictures
Suggestion is to format the memory card and permanently delete all of the images from it. The card should then be able to be reused and you can start taking images again. To format the card go to Menu - setup and press ok - go to format and press ok - go to yes and press Ok. This will clear the card and you are back in business.
SOURCE: After 2 shots I am getting Memory full sign
These cameras have little memory and should be used with a memory card. The erase function may be for the memory card. Memory cards are not expensive now.
SOURCE: How do I clear MEMORY FULL?
buy a memory card reader then transfer your images to your computer if your files is important,if not then delete or reformat
