Ainol Novo 10 Hero 10 Inch Tablet Pc IPS Dual Core 1.5GHz 16GB Bluetoo Logo
ArchRae Posted on Dec 26, 2012
Ainol Novo 10 Hero Tablet won't turn on
Hi. I have had my Ainol Novo 10 Hero for 1 day already there are problems. The screen won't turn on. I had plugged the USB cable in from the tablet to my desktop. I was copying a Video file from my Desktop Computer to the Ainol tablet. I cancelled the data transfer as it was taking to long. I unplugged the USB cable. The Ainol tablet then seemed to shut itself down. It no will not turn on. I plugged in the power adapter. I can not even tell if it is charging. I can not see the charging icon. It looks completely dead.Can anyone help me with this? Thank you very much in advance.
  • Anonymous Aug 14, 2013
    Hi i have my aniol novo 10 hero quad core for one week but from many days my tab is working almost itself... i dont know why.. but when i start my tab so it started to work by it own...i think it has its own life...please please tell me how to fix it please...i would be very thankful to you...
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jan 21, 2013
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
4281
Points
Excuse me, can you help me? my tablet doesn't work too.I just browse in the internet and after that i locked it and now it doesn't work ? What am I should do?
Anonymous
Level 1:
New Friend:
  • Posted on Dec 28, 2012
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
4281
Points
Try pushing in the mic button with a safety pin. That used to work on mine, now mine wont turn on at all. : (
  • ArchRae Dec 29, 2012
    Thanks a million. That did the trick. Sorry to hear that you are still having problems with your machine. It seems from various forums that this is a common problem.
    Thanks again.
  • Anonymous Apr 09, 2013
    sorry for what happened to ur tablet, i did the same and it worked, thanks, but can u tell me how come it didn't work with u any more?
Kin yawn
Level 1:
New Friend:
Problem Solver:
  • Contributor 5 Answers
  • Posted on Jun 04, 2013
Kin yawn
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
5
Questions
Helped
5181
Points
7
Bal2what mean not work; the on/off switch not or enen the pin hole switch not work. If this is the case then check power supple. Put on charge then pin hole switch.if all failure to boot up the set then it is dead dead.my set the on/off not work but pin hole switch work and even reset to factory setting the on/off still not work that indicat hardware issue.as I know some tablet the switch easy to dislocat for the oringinal location then even push the botton can not reach to the switch.only way to fix it is open up the set.your problem may just power failure.
1 Related Answer
Robert A Catalus
  • 11 Answers
  • Posted on Dec 06, 2013
SOURCE: Ainol Novo 10 Hero 10 won't turn on :( it appears dead :'(
Sounds like it is not charging.
The unit will power on momentarily if low batter but power off straight away
Get an electrical competent person to check the output of the power unit or use know good unit.
1helpful
Will not turn on
If tablet keeps burning out charges it is due to the fact that an internal short in the tablet is making the charging unit exceed its parameters and allowing it to burn itself out. The issue is with the tablet, not the chargers.
Ainol Novo 10 Hero Tablet won't turn on/off on power button... it only works from reset button... also auto rotate doesnt work... Also whole tablet gets stuck always after 10min useage... ideas???
I have same problem as you have: the on /off switch completely not work . It cannot start only way use the reset pin then cannot off.Mine also has freezing problem.I went to setting then go to factory reset erase all my data. The freezing gone but the on / off switch still not work then I think this could hardware problem. Only way is open it up.Since this is a traumata act I have to use as the last act.Meanwhile I set the display screen close in 2 minutes when want to stop it.Any one here have any better idea please help.
My ainol novo hero is frozen on home screen
The simple way to tempary solve this problem by just use a pin to insert to the small hole next to the power supply hole.this will turn off the set and start from begining(not reset to factory setting).If your problem back again then need to consider to go to backup and reset to reset to factory setting.It will lose all your data.If still not work contact the factory and install update firmware./
Top Ainol Tablets & eReaders Experts
k24674
ADMIN Andrew
ADMIN Andrew
Are you an Ainol Tablet and eReader Expert? Answer questions, earn points and help others
