Kodak EasyShare DX3700 Digital Camera Logo
Posted on Dec 26, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Warning card door was opened - Kodak EasyShare DX3700 Digital Camera
Anonymous
Level 3:
Genius:
  • Kodak Master 1,019 Answers
  • Posted on Jan 24, 2013
Anonymous
Kodak Master
Level 3:
Genius:
Answers
1019
Questions
0
Helped
102438
Points
1576
Hello, Do not understand "warning card door was opened" What is the problem you are having ? Please repost with more details.
2helpful
2answers
The doors opening warning light
Check/adjust the door locks.
Why do I see a rear access open and a gate ajar warning on insument panel, even though it is locked?
[SOLVED] False Gate Ajar/Rear Access Open warnings: follow up post ...
forums.trailvoy.com > ... > 02-09 General Tech Q&A > General
Dec 28, 2009 - 4 posts - ‎2 authors
[SOLVED] False Gate Ajar/Rear Access Open warnings: follow up post General. ...2002 Chevy TrailBlazer LTZ ... In cold weather, I have a constant "gate ajar" warninguntil the ... Should I try to unhook/rehook the connections to the BCM? ... You might confirm it by starting the vehicle cold, see that you have ... Annoying tailgate ajar won't quit going off on 04 gmc ...
Feb 4, 2010
Rear latch assembly not functioning on Lift Gate
Oct 12, 2009
Gate Ajar - turning off
Jul 1, 2007
passenger door ajar
Nov 9, 2005
More results from forums.trailvoy.com
Rear access door ajar - false signal - Fixya
www.fixya.com/cars/t22610885-rear_access_door_ajar_false_signal
How can I lock a renault megane 56 plate without the key card as it is not working
Locking/Unlocking the doors from the outside
This is done using the RENAULT Card; see the "RENAULT Card" information in Section 1.
In certain cases, the RENAULT card may not work:
- if the RENAULT card battery is weak, flat, etc.
- if equipment operating on the same frequency as the card (mobile phones, etc.) is used;
- vehicle located in a high electromagnetic radiation zone.
It is then possible:
- to use the key integrated into the card to unlock the front left-hand door;
- to lock each of the doors manually;
- to use the interior door locking/unlocking control (refer to the following pages).
Using the key integrated in the RENAULT card
Insert key 1 into the lock in the driver's door and lock or unlock. Locking the doors manually
Turn screw 2 with the door open (using the end of the key) and close the door.
This means that the doors are then locked from the outside.
The doors may then only be opened from the inside or by using the key in the front left-hand door. Interior locking/unlocking door control
Switch 3 controls the doors, boot and, depending on the vehicle, the fuel filler flap simultaneously.
If a door or the tailgate is open or not closed properly, the doors and tailgate lock/unlock quickly.
If you need to transport objects with the boot open, the other opening elements can still be locked: with the engine stopped, press switch 3 for more than five seconds to lock the other opening elements.
Locking the doors without the RENAULT card
For example, in the event of a discharged battery or the RENAULT card temporarily not working, etc.
With the engine switched off and an opening element (door or boot) open, press and hold switch 3 for more than five seconds.
When the door is closed, all the doors and the tailgate will be locked.
Unlocking the vehicle from the outside is only possible with the RENAULT card in the vehicle's access zone or using the key integrated in the RENAULT card.
Door and tailgate status indicator
With the ignition on, the warning light integrated in switch 3 informs you of the locking status of the opening elements:
- indicator light on, the doors and tailgate are locked,
- indicator light off, the doors and tailgate are unlocked.
When you lock the doors, the indicator light remains lit and then goes out.
Door open warning light does not function
for some a blessing, other>????
all doors, or just one,
do other warnings work, key left in, ? belts not attached?
if only one door fails and all other warnings work
then the door switch is bad.
Constant warning tone when car in drive
This warning sign signals that there is a problem with the latches on the sliding doors. Clean them lubricate them, and if the problem does not go away, replace them.
Door chime and open door warning light won't turn off
more than likely you have a bad door switch check the driver side first
1helpful
1999 Infinity QX4. Door Open warning light
usually on post where door closes, or in jamb by hinge area. Open door & try pushing any button/pin like object or may be a lever style too, with thumb or finger.When interior light goes out, you found it
Key on engine running trouble code 55
Warning Chime Systems The generic electronic module (GEM) will sound the following warnings:
  • key-in-ignition warning
  • safety belt warning
  • headlamp switch ON warning
  • door ajar warning
Headlamp Switch On Warning The generic electronic module (GEM) sounds when the driver door is opened while the headlamp switch (11654) is in the PARK or HEAD position, and continues to sound at a rate of 4 chimes per second until the headlamp switch is turned off or the driver door is closed.
  • When the headlamp switch is in the PARK or HEAD position, power is supplied through Circuit 293 (O/R) to the GEM.
  • When the driver door is open, the driver door open warning lamp switch (10B997)is closed and ground is supplied to the generic electronic module (GEM).
A delayed headlamps on repetitive chime will sound for a period of three seconds beginning twenty seconds after the key is turned to OFF, LOCK or ACC, the headlamp switch is in the PARK or HEAD position, and the driver door is closed. Delayed headlamps on is terminated by opening and closing the driver door again.
Door/Liftgate Ajar Warning The door/liftgate ajar warning functions as follows:
  • The generic electronic module (GEM) sounds a warning tone for one second when any vehicle door, liftgate window or the liftgate is ajar without any other door already open and the ignition switch is in the RUN position.
  • Power is then supplied through Circuit 627 (BK/O) to the door ajar warning indicator lamp which remains illuminated until all doors are closed or the ignition switch is no longer in the RUN position.
Key-in-Ignition Warning The generic electronic module (GEM) sounds when the LH front door is opened with the key in the ignition switch and continues to sound until the key is removed or the door is closed.
  • When the key is in the ignition switch, the ignition key warning switch terminal and wire (11A128) is closed and ground is supplied through Circuit 158 (BK/PK) to the generic electronic module (GEM).
  • When the LH front door is open, the LH front door open warning lamp switch (10B997) closes and ground is supplied through Circuit 57 (BK) to the generic electronic module (GEM).
Safety Belt Warning When the ignition switch is turned to RUN or START from the OFF or ACC position and remains in RUN or START, the chime will sound for six seconds or until the safety belt is buckled. The safety belt warning indicator lamp (10C859) will turn on for 60 seconds, or until the LH front safety belt is fastened. Both the chime and lamp activate at the same time. If the safety belt is buckled when the ignition key is turned to RUN or START from OFF or ACC, the lamp will prove out for two seconds, but chime will not be activated. Any time the key is changed to RUN from START while the safety belt warning indicator is activated, the safety belt warning indicator will remain activated until either the timing sequence has been executed, or the safety belt is buckled.
2answers
Master warning light
check all 5 doors for closure, the rear hatch usually has the carpet stuck in it.
"Card-Cover Open" Warning
Have same problem when camera is used underwater. Take out battery and xd card. Put camera in front of fan with lid open and facing fan for several hours.
Top Kodak Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Kodak Camera Expert? Answer questions, earn points and help others
