No power to the dvd player and front panel will not respond to either remote or panel push buttons. Display shows "LOAD" and does not change.
SOURCE: Progressive Scan Mode Resetting
Hi, Open the CD and press return on the remote to reset it back to Interlace mode. Thanks Annarr
SOURCE: wont turn on
sounds like you gotta power supply problem in the main unit. to repair this your gonna need a service manual most likely or you have to take it in to a repair shop to estimate for you .. if you post a schematic we will assist you in trouble shooting if you have any previous experience. Good luck.
SOURCE: freezing
sounds like a bad solder joint that is cracked...as GPX heats up, the crack starts to get bigger and cutting off electric circuit, then cool down closes the gap and current resumes. First try breaking and then making all possible connections outside then inside unit. Then, if no success, remove the circuit board and clean it with alcohol and brush then carefully look at each solder joint with a magnifying glass. If one found, simply re-solder it.
SOURCE: dvd GPX cannot find the remote code for it
I need to program a universal remote with my GPX DVD player
does anyone know the 3 digit code?
SOURCE: remote codes
Radio Shack has a website for all of it's universal remote codes for the remotes it sells at www.rcinfo.com. There you'll find what you're looking for.
