1.) Download the "system.zip" file and unzip (using a program such as WinZip, 7-Zip, WinRAR, etc.) the file.
2.) You will then need to connect the Tabeo tablet to your PC and then select the "Turn on USB storage" option on the screen once it comes up.
3.) After the file has been unzipped it will need to be transferred to the main folder, or "root directory" of the Tabeo tablet. Please ensure that you do not place the "system" folder in any of the folders already in the "root directory".
4.) You will now need to have to go into Settings application (located under the apps list from the top right corner) and go down to "About tablet" and select Start Wizard. Then turn the unit off and on again.
I downloaded the system.zip , connected the tabeo but nothing comes up so I can "turn on USB storage" I know I'm probably just overlooking something . Please help.
i can not download the system zip says there is no file what can i do? Robin Ginn if all ready has it can you pass it to me? here my mail [email protected]
4.connect ur unit into ur comp. & open the drive on ur comp. so u can see all the folders in it. copy the recovery app folder that actually contains the apk files into the unit called system. 5.once the copy is finished disconnect the unit from the computer and on the unit go to settings-about tablet-start wizard. confirm you wish to run the app then turn the tabeo off then back on and u will b walked through the default appz will b re-installed to the unit
OR IF YOU CLICK ON THE TABEO CHAT SUPPORT APP CLICK ON CHAT NOW THEN WHEN THE PAGE LOADS LOOK DWN ANOUT HALFWAY DWN THE PAGE AND IT WILL EXPLAIN HOW TO GET IN THE PARENTAL SETUP AND THE RE INSTALLED APP
Simply reset to factory settings I had the same problem
no that doesnt work resetting is what lost the apps in the first place
same here. I accidently deleted it all :( if you find a solution please post!!
Same here, ReSetting is the reason we have this question! Ugh I'm so Frustrated
