Remote Start System  Logo
DOUG LYBECK Posted on Dec 25, 2012
INSTRUCTIONS FOR VIPER 7641V REMOTE, HOW TO PROGRAM REMOTE
2 Related Answers
Anonymous
  • 53 Answers
  • Posted on Jul 12, 2009
SOURCE: Viper 5701 remote programming
1st you need to enter the remote into progamming Hold the Function button until the remote gives a long beep and LED light comes on the remote a (it takes about 8 sec.) Then press and hold the remote start buttom until the remote beeps 3 times and LED lights up. Now your ready to program the remote
One of the door has to be open . Insert the key - turn the key to the On position then press the button on the antenna once and then press it again and hold it
You hear a chirp and then you press the lock button on the remote and then you hear a second chirp to recieve confirmation and then release the button and the turn off the key .
Remote should be program
Anonymous
  • 132 Answers
  • Posted on Apr 04, 2010
SOURCE: how to program viper 5701 remote
Unlock doors
Push and hold f button for 8-10 seconds until amber light is on solid
Push Remote start button for about 4 seconds till amber light flashes 3 times
Put key in to IGN position
Push valet (black button) one time and release
Push and hold valet button
Push either lock or unlock on viper remote
Key out of IGN
Test unit
The horn or siren may sound afterwards to indicate SUCCESS!!!!!!
I need to know how to program remote
To program a new remote to the system; open door, turn ignition on, press and release valet switch one time then, press and hold valet switch. System will respond with a chirp. Now press lock button on remote. System will respond with a long chirp.Turn ignition off. Test system. Repeat for additional remotes.
1helpful
I have a viper remote rpn 7641V
Yes it should but you will need the wiring diagrams to hook it up. Why do you want to add a system to a car that already has an excellent factory installed system??
2answers
Is there a user guide for the viper 7641 remote starter
First of all, thank you very much Rob for choosing FIXYA today for your online technical support needs.
Here is a direct link to the ONLINE USER'S MANUAL for that model:
http://www.directeddealers.com/manuals/og/viper/G562VL_07-06.pdf
To view the Owner's Manual with Operating Instructions just use your mouse to click on the link, which is the underlined and blue highlighted section of text just above.
This will open a new web browser page automatically for you and allow you to view the information at the website indicated and the contents of the Owner's Manual.
You may need ADOBE READER installed on your computer to read PDF documents, although many computers already have this type of utility pre-installed.
You can download this free at WWW.ADOBE.COM if necessary. Click on the DOWNLOAD ADOBE READER button on right side of the ADOBE home page when you get there, then follow the onscreen instructions to install the software on your computer.
I truly hope that was helpful to you.
Good luck and take care.
Joe.
Just want to know how it works
When you press a button, it broadcasts a coded ultra-high frequency radio signal. If your car is within range, the radio receiver in the remote control lock circuit decodes it. If the identity portion of the code matches the number in the receiver, then the command code (lock, unlock, or whatever the other two buttons are for) is decoded and the receiver turns on the equipment in the car that does the desired operation.
2helpful
I need instructions on how to use my viper 5101 remorte starter
go to www.directed.com this is the manufacturer of the viper remote starters, there you should be able to download instructions.
Here is how you program the viper 5101 remote.
Programming the Viper Remote Starter 5101
Unlock the doors before starting
Put key in IGN to the on position but don
11helpful
How to program viper 5701 remote
Unlock doors
Key out of IGN
Test unit
How do program a replacment two way remote for
If you go to the website then to the support page under guides, you can find your models manual which give you installation and reprogramming instructions.
35helpful
Top Viper Vehicle Parts & Accessories Experts
oneStan
oneStan
ZJ Limited
ZJ Limited
Are you a Viper Vehicle Part and Accessory Expert? Answer questions, earn points and help others
