Question about Toshiba Computers & Internet
Toshiba satellite M645-S4070 freezing up
Within minutes system freezes
  • 358 Answers
Hello Bdahlias,
This is likely to be as a result of your processor over-heating, maybe because of your environment, possibly because the air-vent is blocked, or because the fan is not cooling the processor properly again...especially if you use the laptop on the bed a lot, this blocks the vents and sucks in wools/dusts e.t.c
Therefore my suggestion would be for you to unscrew your laptop (If you can do it by yourself), and try to clean, or better still replace your processor fan.
Also clean the air-vent where air is supposed to enter the laptop If you cant do it by yourself, you can easily get a technician to do it for you.
A quick tip you can try now is : Locate all the vents on the laptop, where the fans are placed and blow air into it to forcefully clear some dusts, then power on the system to see if there's any change.
Also, remove all your RAM(Memory Sticks), and clean the tip of the connector with an eraser, and re-insert it one after the other.
That is, if you have two of them, after you insert the first one, put on your system and see if it works, then do the same thing with the other one.
If the two of them works, them insert the them all. but if it is just one that worked, just remove the other one that is not working and replace it.
If the two of them are not working, then try to get a RAM of the same type to test it with, either from a friend or a technician.
Then always remember to make sure that your laptop is in a well ventilated, cool environment and that the environment is free from dusts.
Also, some other things you can try out are: Try to power on your laptop without inserting the battery, just use that AC Supply only. this lets you know whether your battery is faulty.
Kindly let me know how it goes after you've tried all these.
Hope this helps you out.
Good luck and Thank you for using Fixya!
Posted on Dec 25, 2012
6ya staff
SOURCE:
Kyocera HP Expert
  • 523 Answers
SOURCE: Toshiba Satellite L40-17U freezes up after 5 minutes
Norton antivirus takes big space in the computer coz it try to block all the files and make them secure, so it slow down your computer specially if you have vista and with low Ram. so First Try to remove norton and check your computer? it seems the Ram is low so its unable to continue its froze, or if you feel its over heat, check the fan on the Cpu could be not working which make ur Cpu Froze.
I’m happy to help further over the phone at https://www.6ya.com/expert/mustafa_06f84c65ab5cc745
Posted on Jun 17, 2009
Katwal
Raman Katwal
  • 129 Answers
SOURCE: toshiba laptop freezes using webcam
Do you think its due to external webcam ?
You mean that if you dont use webcame it works fine.
If this is the case you just uninstall the webcame drivers from Add/Remove Programmes under Control Panel.
Try to get the latest drivers from webcame manufacture website which suits your windows(OS) and install it again.
Posted on Jul 31, 2009
bob_computer
Project NOMAD
  • 3153 Answers
SOURCE: My toshiba satellite laptop freezes 5 min after
It may well be some form of virus or spyware.
It may also be that you have too many applications running at once eg. lots of toolbars and instant message typ programs.
It can also happen on graphic intensive applications.
You should rule out nasty stuff first.
MBAM !
for a free one its pretty darned good !
From a CLEAN computer download and put on a flash drive.
Copy to your DESKTOP on the suspec computer.
Run it but dont change any options just use what it offers.
When its done let it clean anything it finds.
Its where I always start with an infected machine.
As for antivirus AVOID Norton or Mcafee but try the AVG FREE version MBAM should clean up without buying
Only continued use would require purchase As for too many applications that would be up to you to decide what you REALLY need and dont. Most toolbars are a waste of both time and space and can hog computers down. Maybe a good clean up is in order ?
It may just be a "leaking application"
These are badly coded programs that dont release memory when they should and just keep taking more to do the same job.
May I suggest you download
"hijackthis"
It is a program that can make a report on what you have running in such a way that you can post that information to certain sites and experts there will look at it.
They will then give you reccomendations as to how you can remove programs or fix some issues that may be upsetting your computer.
Dont post the log here but follow the nstructions and help the program offers to send it to one of the sites it will offer you.
If you understand startup lists you may even be able to spot som things yourself that you dont want to run and disable them from hijack this.
Posted on Nov 20, 2009
Anonymous
  • 9 Answers
SOURCE: my toshiba satellite l300-1aq laptop is freezing
When you power up, turn the notebook so you can see if the cooling fan is running.
It sounds like the self protect shut down from over heating.
Posted on Feb 01, 2010
big_al_1982
Allan Browne
  • 95 Answers
SOURCE: toshiba satellite L505D GS6000 mouse freezing
reinstall the driver for the mouse touchpad
Posted on Feb 23, 2010
Where are the jumper locations for bios on a Toshiba m645-s4114?
just remove the CMOS battery for 10 minutes after you open the back cover..
Sep 11, 2015 | China Toshiba Satellite M645-S4110...
M645-s4070 keyboard not working
I think your correct, it's a hardware issue, a lose connection perhaps. Here's a vedio that may help:http://www.youtube.com/watch?v=GcM9knr_P4Q
Dec 03, 2012 | Toshiba Satellite M645-S4061 Notebook
Problems with my Toshiba Satellite L675D freezing up
start the PC in safe mode (f8 on boot) and see if it still freezes. If not do the system scan from within safe mode
Sep 27, 2017 | Toshiba Satellite L675DS7040 AMD Athlon II...
Severe Cooling System Issues
Yes. bring it to a laptop repair shop. But also purchase a laptop cooler as well.
Jun 30, 2012 | Toshiba Satellite M645-S4070 Notebook PC -...
How can i remove a toshiba satellite A500-01w keyboard?
try this first
a. turn over computer overnight and let it 'drip dry'
b. take a hair dryer on low heat and fan and GENTLY run it over the keyboard about 1 inch back and at angle
try that first and report back
you might get lucky
Jun 14, 2012 | Toshiba Computers & Internet
Hi there! I bought Toshiba satellite M645 laptop a few weeks ago, and very unlucky I got the defective (I assume) one. Most of the time it freeze, need to force the power off button to shut off....
I would, call Toshiba's Corporate Head Quarters, ask for a Executive Customer Service Supervisor, explain the issue (Be Nice... No Matter How Upset You May Be) and request an upgrade to the next model. All they can say is no, if yes, you're golden; if they do say no - at the very least, they will offer a: re-re-placement and most likely tell you if you have trouble with the 3rd one (HP did that with one I sent back for a family member - they have a 3 time rule).
TOSHIBA USA WARRANTY/SUPPORT PAGE\
Toshiba USA Corporate HQ
Irvine Headquarters
19900 MacArthur Boulevard, Suite 400
Irvine, California 92612
Telephone: (949) 623-2900, Facsimile: (949) 474-1300
G'luck
Thank You For Choosing FixYa~!
Don't Forget To Vote :-)
Mar 18, 2011 | Computers & Internet
Rotating the volume wheel on my laptop freezes Windows
My toshiba satellite l300-1aq laptop is freezing within a minute of start up? How can I root cause the issue?
Apr 02, 2009 | Toshiba Satellite Pro L300 Notebook
Toshiba Satellite M45-S265 Periodic Freezing, resumes, clock stop
do a virus scan
in add/remove uninstall any programs you no longer use
then do a disk defrag
then a scan disk
have you made any changes to system
please let me know if this has helped
don't forget to rate
Nov 30, 2008 | Toshiba Satellite M45-S265 Notebook
Computers & Internet Logo
163 people viewed this question
Top Toshiba Computers & Internet Experts
Ekse
Alun Cox
Thomas F. Schneider
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
